ajlskater1
    Thu Feb 02, 2012 5:32 am
Had to weld up 200 of these on Friday. Was a good challenge. The material was .070 5052 and the hole was only .090 away from the edge of the hole and customer didn't want the hole to be distorted.
Nice work, what machine are you using?
    Fri May 27, 2016 11:00 am
    Atlanta, GA
What is the part for?
Raymond
Everlast PowerTIG 255EXT
ajlskater1
LtBadd wrote:Nice work, what machine are you using?
I am using a dynasty 350. It is a part of this larger assembly we do for this company. Not sure it's exact use.
    Thu Jan 24, 2013 6:44 am
Beautiful!
    Thu Dec 25, 2014 9:25 am
    near Chicago
zank wrote:Beautiful!
Yeah!
ajlskater1
Thank you! Not sure it's on the same level as your work! Love seeing your bike frames!
Coldman
    Mon Dec 15, 2014 2:16 am
    Oz
Weldporn
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
and two hundred of them, holy crap.
awesome
motox
    Delaware
pulse?
ajlskater1
motox wrote:and two hundred of them, holy crap.
awesome
Was a nerve racking couple hours of welding lol. Had to focus really hard
ajlskater1
motox wrote:pulse?
No pulse. I used 200 en 115 ep balance of 60 and frequently of 100
motox
    Delaware
very steady hands.
'Stang
    Sun Aug 03, 2014 11:12 pm
    Rogersville, MO
Oh Yeah! I want to weld like that when I grow up! Lol Just got to decide when I am going to grow up! Nice work!
    Sun May 01, 2016 7:46 am
    Fort Myers Florida
Outstanding quality!
Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
Looks awesome! I love 5052...
motox
    Delaware
"No pulse. I used 200 en 115 ep balance of 60 and frequently of 100"
did you start at 105 amps and just peddle the pool?
    Atlanta, GA
I believe that means that he has a machine which will allow you to set differeng amperages for the positive and negative sides of the ac waveform. Jody showed one of those machines in a video recently.
Raymond
ajlskater1
RamboBaby wrote:I believe that means that he has a machine which will allow you to set differeng amperages for the positive and negative sides of the ac waveform. Jody showed one of those machines in a video recently.
This is correct. The dynasty 350 allows you to independently change the en and ep sides of the actual wave form and change the balance all independently. Those were the setting for the little part. The other part I set the machine at like 350 en 250 ep 70 percent balance and 250 hz, that's normally how I do mostly aluminumunless it's really thin or dirty. I don't max out the pedal, I like to feather it
