rahtreelimbs
    Mon Jun 14, 2010 10:39 pm
Can I get a breakdown of aluminum filler rods and their uses and benefits???
    Fri Feb 12, 2010 10:48 am
    YOUNGSTOWN, OHIO
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
rahtreelimbs
Thanx!
Ultralow787
    Fri Apr 29, 2011 11:30 pm
    Ontario, Canada
I have always been taught that 4043 and 5056 cover most needs. You can tell them apart by dropping them on a table. The 5056 (being harder) makes a sharper sound, and the 4043 makes a dull thud sound.
The chart that Jim posted the link to really covers everything in detail though.
Perfection is impossible, but if you strive for perfection, excellence is obtainable!
1983 Canox "Sparkler" 225 AC Stick Welder
Hobart 210 MVP MIG Welder
Harris "Spitfire" Oxy-Acetylene Set
capozzoli
    Fri Dec 23, 2011 5:07 pm
Use the 5056 if you are gonna have the welded piece anodized. Any other filler will turn black. Found that out the hard way. The real hard way.
Welding everything from the crack of dawn to a broken heart.
newly_welding
    Wed Feb 08, 2012 2:14 am
Why does the other filler turn black? I found that out the hard way too :)
ajlskater1
    Thu Feb 02, 2012 5:32 am
Just wondering what is the best filler for 5052 is? At our shop we normally run 4043. Just thinking about trying something else. Not to concerned if it turns black after anadizing as the 4043 we use already does and the customers don't care. Anything better as far as strenght and apperance?
nova_70_383
    Fri Nov 06, 2009 5:51 pm
there are many aluminum rods out there! i use 5356, 4047, 4043, 4145, 4008. if you weld cast aluminum 4008 is for A356. 4145 is for 319, and 355. i never used it, but 4009 is for A357. if you dont know the alloy 4043 is a good bet. it covers most alloys. 4047 is acceptable where 4043 is ok. 4047 has like 12% silicon and has a wet flow characteristics that let it wet in and flow nice especially with porosity in cast aluminum. 4145 does this too but according to the alotec filler rod chart has some disadvantages. color match and corrosion resistance are two. 5356 works for 520 and 535 aluminum/magnesium alloys. some people call this al-mag. the big down fall for most people is the cost of the odd ball rods, especially if you have to get them in 10 lbs box.
