Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
My wife and son picked up a new fire truck toy at a yard sale, I noticed it had a ladder snapped to the side of it but nothing to mount it to. So what does a good dad that can weld and fabricate do.... Make one, of course out of stainless..lol
He was the happiest little man when he woke up and saw the ladder on it.
Rick_H wrote:My wife and son picked up a new fire truck toy at a yard sale, I noticed it had a ladder snapped to the side of it but nothing to mount it to. So what does a good dad that can weld and fabricate do.... Make one, of course out of stainless..lol
Well we now know where it won't break!
    Sun May 01, 2016 7:46 am
    Fort Myers Florida
We shipped over 20 tons of fabricated steel today, and as a father of seven, what you welded today is worth 10X more in my opinion. :D
Well Done !
    Fort Myers Florida
Put in a service for a buddy that just bought property with an orange grove on it. Stand all aluminum built on back of trailer with 4-1/2" Grinder (zip wheels), porta-band and Spoolmatic 30A. Worked pretty well outside, wind kicked up once and made me curse, other than that no issues at all.
Aaron@6061.com
    Thu Jan 14, 2016 10:16 am
This is a great fix! I bet there's at least a 50% chance you'll be making a better ladder too when those two vertical attachment points break. Post a picture of that when it happens.
Aaron@6061.com
TV wall mount
    Fort Myers Florida
And a trip to Radio Shack, that thing needs some code equipment. Strobes, LED's and a 120dB siren for mom and dad :lol:
    Fort Myers Florida
Wow, excellent job. I like that. Them freaking mounts at Wal Mart are cheesy and really expensive.
    Sun Jan 27, 2013 6:23 am
    Finland
I usually weld stainless high purity pipes with orbital, but every now and then I need to get my hands dirty with mild steel :D
Which is quite fun to do for a change. No purging etc. just weld that shit together :lol:
So saturday's quick job. Nothing special, just get to work, weld it and get back to home.
12 barg steam pipe Ø114,3x4,2 mm. Root done with 3 mm gap, 2.0 mm wire and 1-2 mm land, about 85-90 amps. Fill with one pass around 100 A and 3.0 mm wire. All was tigged.
Jody's trick works like a charm!
-Markus-
    Fort Myers Florida
That is a crime to cover that weld up with insulation! How long did it take from start to finish?
    Finland
Thanks buddy!
Total time was one and a half hour, but had some problems with water running down the pipe. I think 20 minutes per weld is quite correct guess. I like to do lay wire root, which is really fast. With this technigue I am able to get that line in the middle of the weld and then I know that speed is near 100 mm/min. At 6 o'clock keeping the tip of the wire inside of the pipe and on top just feed it straight to puddle.
-Markus-
    Fort Myers Florida
That is very good time, I hope the customer appreciated the skill and quality! Nothing worse than laying down the perfect bead, and say to a buddy that isn't in the trades "check that out" and he says "what? it's just a weld" lol
Rick_H
    PA/MD
Nice job Markus, tomorrow is Steam Pipe Sunday for me :mrgreen:
Here's a few projects I did today at work...
rolling dollie for a glue wash bucket
Rolled it
Rolled it
finished product, also welded the nipple in the container
air cylinder bracket 1/2" steel, 280amps
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
Rick
looks like that place wold be lost without your talents
Rick_H
    PA/MD
Swapped out some old carbon steam piping for some 316L after we found a leak. 13hrs of work on Sunday but I banged it out, removed the old, fit and welded all new and installed. Did I mention I get double time on Sundays :mrgreen: ...man it was a lot of work by myself. Old pipe is never fun, like those old unions were actually going to come apart...lol damn leak had run down the insulation soaking in, who know how long it's been leaking till I found a small wet spot finally.
One day I learn to have some help, but I find I like stuff done my way, fit tight, the right length I actually measure to the 1/64" quite often..lol Guess that the mech engineering coming out of me. My co workers laugh when I talk in thousandths..lol
The old
The old
Tiny root
Tiny root
Finished joint
Finished joint
My little badass Maxstar 150sth
Old vs new...union isn't tight so it actually is straight...lol
New section installed
Rick_H
    PA/MD
motox wrote:Rick
I appreciate that buddy as much I as also like to think that..they say everyone is replaceable.
    Fort Myers Florida
Damn fine job, but replacing steam and condensate returns with SS, who is doing your water treatment program?
motox
    Delaware
yup they can hire two or three people each having one of your talents and experience...
its the american way of business......
Rick_H
    PA/MD
DLewis0289 wrote:Damn fine job, but replacing steam and condensate returns with SS, who is doing your water treatment program?
Yeah it shouldn't have to be stainless, but in the environment it is in it will help externally as well. I heard we had issues years back, I think it is catching up...that and I have found quite a few sch 40 fittings that were used as replacement over the years. Most of the stuff I find is all threaded, no unions makes it wonderful to work on. Our new external treatment company is Guardian, them seem to have there act together and the readings and boilers are looking much better.
The difference in price from Stainless to Carbon was not as much as I had expected either with piping and fittings, not valves are a different story, they are doubled in most cases.
I'm guessing that in the food proscess you may not return much condensate. This is common and also makes it hard to treat the water. I see lots of condensate that got put in with sch 40 and it just doesn't last. Gets even worse if it's in an area where they wash stuff down.
chillrich
    Fri Nov 06, 2015 11:47 am
Welding table, still need proper bottom shelf.
Posting this pic has taken about the same time as the progress on welding table so far.
chillrich
Turbo
    Fri Nov 20, 2015 4:11 pm
    Milwaukee, WI
We are doing a short run of a new all aluminum schmitt32.com line drilling system. This extrusion was not meant to be used for this part but the steel yard sold us 6063 even though they said they only sell 6061. This is 2.3mm 6463 which seems to machine and weld fine. Butt weld with a little bit of beveling, 3/32 4043 rod, 135 A, 225 Hz, 70 % EN. I did 10 of these. I don't know what the trick is to starting on the end and making it look good, so I started in the middle and welded out. I was getting sooting on the starts and I'm not sure why. I'm guessing that either i need to turn up the pre-flow time or it has something to do with the cleanliness of the metal or tungsten. It's not after dipping. It happens as soon as I start the arc.
Miller Dynasty 210dx
instagram: rsengineeringllc
Turbo
    Milwaukee, WI
This will be mostly hidden. I would like to know if it's possible to melt through this notch from the front. The only way I know of making it look good is to get less penetration and don't want that since this joint should not even be here. If I weld on this side I would need to sand it off. I did a test weld like this, cut, sanded and beat on it and it didn't break.
