    Sun May 01, 2016 7:46 am
    Fort Myers Florida
Phenomenal looking job. Can sum up in one word "Craftsmanship". In my experience I see a lot of the young generation happy with "good enough". It's all in the details.
Maxstar300lx
    Tue Feb 17, 2015 9:44 am
You know...the usual. Bike stuff.
Great stuff.…
I'm noticing a slight difference in the ripples and a different HAZ colouration in these latest pics,
What material are you welding on in these pics?
    Wed Mar 11, 2015 9:13 am
    All around Lake Pontchartrain
This isn't even close to the work others have posted here, but I am proud of it none the less. It's the last one for quite a while. We made 3 test articles, 4 for qualifying and 4 for flight. 12 welds each at 110" each weld.
Bitter sweet as it is, it was good to say "Finished!"
Last one----for a while.jpg (55.87 KiB) Viewed 2669 times
Chris
AWS D1.1, D17.1
    Thu May 07, 2015 11:46 am
    KY.
That's great, but what is it?
Freddie
RocketSurgeon wrote:This isn't even close to the work others have posted here, but I am proud of it none the less. It's the last one for quite a while. We made 3 test articles, 4 for qualifying and 4 for flight. 12 welds each at 110" each weld.
Show off! :lol:
I'd be proud too Chris...is this for the Orion program?
    Fort Myers Florida
Didn't weld it today but this is something I have always had or a similar version. My truck is used for business and family. When I do leave the office to do some real work I call this my quick rig. It is on a 4ftx4ft skid that can be loaded into the bed of my truck or on a trailer with a forklift or overhead crane. The whole package weighs 716 lbs when the welder is full of fuel. It contains my power source (Miller Trailblazer) my torch setup, air compressor, lights, scratch TIG and Spoolmatic 30A. One thing I just added was safety rings on my bottles so I just leave the regulators on full time (quick disconnects for the torch end).
Freddie/Richard:
To answer your question, it is one of the cryo fuel tank domes for the SLS rocket core stage. This one in particular is the aft LOX dome. Once (if) the core stage is complete, the Orion capsule will be stacked on top of the core stage and launched into deep space. The first 2 missions will be to the moon and back. After that, Mars.
http://www.lpi.usra.edu/lunar/constella ... 2-MSFC.pdf
Chris
AWS D1.1, D17.1
    KY.
Cool!
Freddie
weldit321@gmail.com
    Wed Feb 24, 2016 11:52 pm
    Waco, Texas
A little fast and dirty intake job for a friend. It had a Nitrous outlet puck installed and a direct port nitrous system, we are removing both and going with a Nitrous Outlet stinger plate. I needed to weld up all the holes from previous nitrous installs. I will post finished pictures once it's complete.
    Thu Aug 13, 2015 11:38 pm
    Scranton/WilkesBarre, Pennsylvania
One of our buddies dirtbike engine broke a small piece off the bottom of the piston...it mushed around under the crank, causing about 6 cracks in the case that were from 1/4" to 1/2" . Welded them up. Made some backing out of 4" copper pipe and copper buss bar bend to the radius shape of the case . Guy did about 4 rides and one race on it , holding so far .
They told me it was Magnesium ...did the vinegar test on a sanded spot , no bubbles .
3 EngineCrack3 x.jpg (79.44 KiB) Viewed 2741 times
1 EngineOtherSide Welded x.jpg (103.28 KiB) Viewed 2741 times
2 EngineCrack1 Welded x.jpg (48.52 KiB) Viewed 2741 times
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
please explain the vinegar test please.
must have been out sick that day.....lol
    Thu Dec 25, 2014 9:25 am
    near Chicago
motox wrote:please explain the vinegar test please.
White vinegar will bubble on magnesium. It's ok craig, I didn't know about it either till I looked it up. :lol:
motox
    Delaware
jeff
just wondering
I've welded up plenty of ending cases always AL
clutch covers and ignition covers are sometimes Mag
but haven't come across center cases in mag.
thanks for the tip!
They were so sure it was magnesium... anyway, I sanded a little spot clean and put some vinegar...no bubbles.
BigD
    Thu Jan 07, 2016 1:56 pm
Started a new project, finally making my own power rack. Gonna be overkill out of 3x3 .125 but first the bar hooks out of 1/4. Do these welds look ok to you guys? The Miller wizard called for 225-300 amps. I set the Dynasty to 200 and on the outside joints it seems to be too much to me but according to Miller it's not enough. Proud if the machine, the fan never even kicked on high and I was using full jam at 200 amps for a good hour.
Specs:
Dynasty 210
200 amps
Air cooled 17 with stubby lens
15 cfh
1/8 2% lanth
3/32 er70s-2
Fe3c
    Sat Mar 12, 2016 11:32 pm
    Las Vegas
modified a swing arm on a pocket bike for a friend.
Melt all the things.
Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
4" 316l, sanitary, walking the cup
motox
    Delaware
pretty!!
Aaron@6061.com
    Thu Jan 14, 2016 10:16 am
Over the past few days, I made this video showing how to build a flask from start to finish. Any feedback is appreciated. Thanks in advance.
Click here to watch ---->>> https://www.youtube.com/watch?v=jYAk29t ... e=youtu.be
    KY.
Great video, Awesome work.
Freddie
TigMonster
    Fri Feb 05, 2016 5:16 pm
That is slick
Sent from my SM-G920P using Tapatalk
TamJeff
    Tue Dec 04, 2012 4:46 am
Nice.
motox
    Delaware
a couple of nice tricks in that video..
ex framie
    Sun Aug 09, 2015 1:09 am
    Brisbane QLD Land of oz
Nice work.
Another 15 grand in tools and a lot more tig practice and I'm there........
Seriously impressive build and video, great skills.
Cheers
Pete
Aaron@6061.com
ex framie wrote:Nice work.
Cheers
Thanks for all the positive feedback
While the $15k in tools does make it a LOT more pleasant to build, It can be built with about $150 worth of tools (excluding the welder):
-hack saw
-hand file
-tap
-hand drill
-countersink bit
-mallet
-hand grinder with flap disc
-bench vise
I'll post up a video (hopefully within a week) on how to build one of these from scratch, along with the CNC machining:
