- DLewis0289
Phenomenal looking job. Can sum up in one word "Craftsmanship". In my experience I see a lot of the young generation happy with "good enough". It's all in the details.
Maxstar300lx
- Maxstar300lx
Great stuff.…You know...the usual. Bike stuff.
I'm noticing a slight difference in the ripples and a different HAZ colouration in these latest pics,
What material are you welding on in these pics?
- RocketSurgeon
This isn't even close to the work others have posted here, but I am proud of it none the less. It's the last one for quite a while. We made 3 test articles, 4 for qualifying and 4 for flight. 12 welds each at 110" each weld.
Bitter sweet as it is, it was good to say "Finished!"
- Last one----for a while.jpg (55.87 KiB) Viewed 2558 times
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
- big gear head
Show off!RocketSurgeon wrote:This isn't even close to the work others have posted here, but I am proud of it none the less. It's the last one for quite a while. We made 3 test articles, 4 for qualifying and 4 for flight. 12 welds each at 110" each weld.
I'd be proud too Chris...is this for the Orion program?
- DLewis0289
Didn't weld it today but this is something I have always had or a similar version. My truck is used for business and family. When I do leave the office to do some real work I call this my quick rig. It is on a 4ftx4ft skid that can be loaded into the bed of my truck or on a trailer with a forklift or overhead crane. The whole package weighs 716 lbs when the welder is full of fuel. It contains my power source (Miller Trailblazer) my torch setup, air compressor, lights, scratch TIG and Spoolmatic 30A. One thing I just added was safety rings on my bottles so I just leave the regulators on full time (quick disconnects for the torch end).
- IMG_3045.JPG (87.21 KiB) Viewed 2762 times
- RocketSurgeon
Freddie/Richard:
To answer your question, it is one of the cryo fuel tank domes for the SLS rocket core stage. This one in particular is the aft LOX dome. Once (if) the core stage is complete, the Orion capsule will be stacked on top of the core stage and launched into deep space. The first 2 missions will be to the moon and back. After that, Mars.
http://www.lpi.usra.edu/lunar/constella ... 2-MSFC.pdf
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
- big gear head
weldit321@gmail.com
- weldit321@gmail.com
A little fast and dirty intake job for a friend. It had a Nitrous outlet puck installed and a direct port nitrous system, we are removing both and going with a Nitrous Outlet stinger plate. I needed to weld up all the holes from previous nitrous installs. I will post finished pictures once it's complete.
- subwayrocket
One of our buddies dirtbike engine broke a small piece off the bottom of the piston...it mushed around under the crank, causing about 6 cracks in the case that were from 1/4" to 1/2" . Welded them up. Made some backing out of 4" copper pipe and copper buss bar bend to the radius shape of the case . Guy did about 4 rides and one race on it , holding so far .
They told me it was Magnesium ...did the vinegar test on a sanded spot , no bubbles .
- 3 EngineCrack3 x.jpg (79.44 KiB) Viewed 2630 times
- 1 EngineOtherSide Welded x.jpg (103.28 KiB) Viewed 2630 times
- 2 EngineCrack1 Welded x.jpg (48.52 KiB) Viewed 2630 times
White vinegar will bubble on magnesium. It's ok craig, I didn't know about it either till I looked it up.motox wrote:please explain the vinegar test please.
must have been out sick that day.....lol
jeff
just wondering
I've welded up plenty of ending cases always AL
clutch covers and ignition covers are sometimes Mag
but haven't come across center cases in mag.
thanks for the tip!
just wondering
thanks for the tip!
- subwayrocket
They were so sure it was magnesium... anyway, I sanded a little spot clean and put some vinegar...no bubbles.
Started a new project, finally making my own power rack. Gonna be overkill out of 3x3 .125 but first the bar hooks out of 1/4. Do these welds look ok to you guys? The Miller wizard called for 225-300 amps. I set the Dynasty to 200 and on the outside joints it seems to be too much to me but according to Miller it's not enough. Proud if the machine, the fan never even kicked on high and I was using full jam at 200 amps for a good hour.
Specs:
Dynasty 210
200 amps
Air cooled 17 with stubby lens
15 cfh
1/8 2% lanth
3/32 er70s-2
Specs:
Dynasty 210
200 amps
15 cfh
1/8 2% lanth
3/32 er70s-2
- image.jpeg (44.83 KiB) Viewed 2466 times
- image.jpeg (60.21 KiB) Viewed 2466 times
- image.jpeg (34.05 KiB) Viewed 2466 times
- image.jpeg (50.46 KiB) Viewed 2466 times
- image.jpeg (48.19 KiB) Viewed 2466 times
- image.jpeg (53.74 KiB) Viewed 2466 times
- image.jpeg (41.69 KiB) Viewed 2466 times
4" 316l, sanitary, walking the cup
- IMG_20160519_242402291_HDR.jpg (55.19 KiB) Viewed 2726 times
- IMG_20160519_240432488_HDR.jpg (38.05 KiB) Viewed 2726 times
Aaron@6061.com
- Aaron@6061.com
Over the past few days, I made this video showing how to build a flask from start to finish. Any feedback is appreciated. Thanks in advance.
Click here to watch ---->>> https://www.youtube.com/watch?v=jYAk29t ... e=youtu.be
- big gear head
TigMonster
- TigMonster
ex framie
- ex framie
Nice work.
Another 15 grand in tools and a lot more tig practice and I'm there........
Seriously impressive build and video, great skills.
Cheers
Cheers
Pete
Aaron@6061.com
- Aaron@6061.com
Thanks for all the positive feedbackex framie wrote:Nice work.
Cheers
While the $15k in tools does make it a LOT more pleasant to build, It can be built with about $150 worth of tools (excluding the welder):
-hack saw
-hand file
-tap
-hand drill
-countersink bit
-mallet
-hand grinder with flap disc
-bench vise
I'll post up a video (hopefully within a week) on how to build one of these from scratch, along with the CNC machining:
