Hi Guys,
I am currently welding with a #13 shade while welding 4130 thin wall tube (.035 wall @ 35-40 AMPS).
Will a #10 Gold shade be enough to protect my eyes?
A 9 is probably fine but adjustable auto darkening helmets are pretty cheap these days.
The darkness of the shade makes no difference for UV emissions which is what causes real damage, even a clear plastic lens will block all of it. Darkness of the shade is just to keep your receptors from bleaching out which is usually transient. Dial in enough to keep from seeing spots after welding and you'll be fine.
-Sandow
-Sandow
-Charles Dickens
-Charles Dickens
Scooter916
- Scooter916
LtBadd,
I think you answered a question I have.
In this video is this what I should see through my helmet lens or is the video clearer for instruction sake?
I took a welding class and I didn't see the tungsten as clearly as in the video. It felt like I was lookin at a bright glow and was welding by feel rather than seeing as clearly as the video shows. I might have a chance if a darker lens will let me see what I'm doing..
https://m.youtube.com/watch?ebc=ANyPxKp ... WNZioJ_FOc
https://youtu.be/vWNZioJ_FOc
- MosquitoMoto
Scooter916 wrote:LtBadd,
That is pretty much what you should be seeing in my opinion.
I caught on slowly myself and spent far too long stabbing the filler into a bright white patch of nothingness. After a helmet upgrade followed by a bit of tinkering with the shade level, I am now seeing pretty much what you see in the video you linked - the shape of the arc, the glowing tungsten electrode and the puddle directly underneath.
The moment I had this dialled in, my welding improved. Seeing clearly so that you can properly judge arc length and understand what the puddle is doing is half the battle won.
Kym
Kym
(hey Kym, one more post and you've got a 1000!! )
