Nothing exciting but I went to the garage to get something and couldn't resist doing a practice nemesis weld. Normally I have to warm up running beads or I screw up. Did this one cold and it's one of my best yet! Still overheated on me at the end but instead of flaring out like I usually get I backed off, fed more rod and it stayed pretty consistent. I think torch angle is still my enemy. I'm MUCH better but towards the end of a fillet, I have a tendency to go into a bit of a push.
- subwayrocket
Nice stuff Skyline and BigD ! Out here in the garage getting ready to tack up an aluminum box i'm making ...my welding clamps don't grab under my harbor freight welding table due to its design . Decided to mod my clamp. Cut off a short piece of 0.055" square tubing ...cut a little piece of flat stock to cap it ...then clad the top with silicon bronze .
Got a little sidetracked !
The intended project, before getting side tracked .....
- 1 weldingClamp.jpg (54.23 KiB) Viewed 1851 times
- 2 WeldingClamp.jpg (56.82 KiB) Viewed 1851 times
- 3 WeldingClamp.jpg (53.16 KiB) Viewed 1851 times
- Ern FuelTank Alum.jpg (56.71 KiB) Viewed 1851 times
.055" square tube! Maybe you mean 1/2" ? What is that receiver in the background, a Marantz?subwayrocket wrote:Nice stuff Skyline and BigD ! Out here in the garage getting ready to tack up an aluminum box i'm making ...my welding clamps don't grab under my harbor freight welding table due to its design . Decided to mod my clamp. Cut off a short piece of 0.055" square tubing ...cut a little piece of flat stock to cap it ...then clad the top with silicon bronze .
The intended project, before getting side tracked .....Ern FuelTank Alum.jpg
- subwayrocket
It's 1" square tubing , digital guage says 0.055" thick , it's all I had , the flat stock I capped it with is 0.125" .
I've had this stereo since around 1978 ...won it in a bet against my uncle. Me, my grandfather and uncle used to go target shooting in upstate NY at the cabin . I previously won a bet shooting a quarter . They were teasing me about shooting a dime ...I said "I bet you that stereo I can shoot the dime" . I hit that dime at about 40 ft out ....he was pissed ...tried to re neg but my aunt raised hell and I got the stereo. It's a 1976 Fisher Studio standard. It cranks . Got a pair of old Bose 901's out here in the garage too. I wish I had a Marantz !
- Fisher.jpg (42.29 KiB) Viewed 1833 times
901's rock, nice setupsubwayrocket wrote:It's 1" square tubing , digital guage says 0.055" thick , it's all I had , the flat stock I capped it with is 0.125" .
ex framie
- ex framie
John Deere ehWJH wrote:Sorry, no pics.. Welded up a busted rusted John Deere mower deck. The welder went a decent way for paying for itself.
I think they make them cracked
I bought mine second hand and yep in the last 2 years I've had the deck out of it twice, which is more often than I've changed the oil.
I will give JD one thing everything is available as a spare, even if a new stamped deck is $1000.
Pete
Hollywood1
- Hollywood1
getting better at tubing fit ups.
- 20160118_142642.jpg (31.24 KiB) Viewed 2133 times
- 20160110_133847.jpg (23.52 KiB) Viewed 2133 times
- 20160118_142711.jpg (24.29 KiB) Viewed 2133 times
Hollywood1
- Hollywood1
I added a few more cracks when I beat the deck back into submission with a sledgehammer. Previous owner apparently hit something at full speedex framie wrote:John Deere ehWJH wrote:Sorry, no pics.. Welded up a busted rusted John Deere mower deck. The welder went a decent way for paying for itself.
Is there something wrong with my hearing or did you just repeat yourself...?WJH wrote:I added a few more cracks when I beat the deck back into submission with a sledgehammer. Previous owner apparently hit something at full speedex framie wrote:John Deere ehWJH wrote:Sorry, no pics.. Welded up a busted rusted John Deere mower deck. The welder went a decent way for paying for itself.
Don't ever let some psychiatrist tell you to work on your "coping skills"....Hollywood1 wrote:getting better at tubing fit ups.
Hollywood1
- Hollywood1
Some old job, steps, platform and railing on SS corn hopper in popcorn factory. 2" schedule pipe bent, some 2" boxes and 1/8' checker plate. Cut, bent and tig'd together.
Below conveyor for popcorn as well, had to fabricate 5 of them as health and safety inspection did not like the rust on the old ones. Pretty nice job, a bit tricky to weld cross brackets holding the sides as easy to distort the 1/8" side plate.
- Hopper
- IMG_2838.jpg (75.45 KiB) Viewed 1858 times
- Hopper
- IMG_2839.jpg (83.42 KiB) Viewed 1858 times
- Conveyor
- IMG_2633.jpg (50.55 KiB) Viewed 1858 times
Slawkos
AFR_Autoworks
- AFR_Autoworks
Working on my first turbo manifold.Every time I pick up my welder I find myself getting better!
- image.jpeg (62.65 KiB) Viewed 1832 times
- image.jpeg (38.77 KiB) Viewed 1832 times
- image.jpeg (91.85 KiB) Viewed 1832 times
- image.jpeg (51.3 KiB) Viewed 1832 times
Tokoroa_Welder
- Tokoroa_Welder
Hollywood1
- Hollywood1
Hollywood1
- Hollywood1
- dynasty200sd
Are the runners of the turbo manifold being kept equal length?AFR_Autoworks wrote:Working on my first turbo manifold.
AFR_Autoworks
- AFR_Autoworks
Yes, the runners at equal length and also equal degree of bends. I did change one runner from the way it is in the picture. Also, no pulse. Sch10 304ss welder set at 100amps but pedalling out. I get a puddle started, dab at it quickly just on leading edge of the puddle until it fills up just flush with the material. One you get the weld height continue to dab quickly and start moving. I really am fond of this technique for welding this stuff. It is easy to stay consistent.
- big gear head
Hollywood, I like the way that looks. I think you are getting good penetration and enough filler to make it strong. Much better than what I have seen on a lot of other cars.
Freddie
AFR_Autoworks
- AFR_Autoworks
Finished product
- image.jpeg (54.26 KiB) Viewed 1647 times
- image.jpeg (78.33 KiB) Viewed 1647 times
