Len,
That's allot of great information Len, thank you for describing the torches and models, this really helps me make a decision on the entire water system. I will not be welding anywhere near 300 Amps with my current machine, but having the capability available for a future TIG welder purchase with greater current output capability frees me from having to purchase a cooler at that time, spreading the $ load over time.
The CK230 being the same size as the CK200 interests me. The CK230 torch head must be slightly larger than the CK200, is the weight of each comparable? If so I may consider skipping the purchase of the CK200 and go for the CK230. I do plan on welding 0.125" to 0.1875" of deoxidized copper in short beads of 1.0 inch, but numerous welds of this length with time gaps in-between. One of my projects requires welding 0.125" deoxidized copper in tight spaces, 6" x 4" x 1.5", but for short periods of time. I will review the CK catalog again, applying what I now know.
On past aluminum welds I had to use my Spool gun with my MM251 to weld anything greater than 0.1875". The Spool Gun bead definitely penetrated, sometimes a little to much. The speed had to be carefully controlled, typically medium to fast, difficult to do when I am the one running the gun.
Once again, thanks for the great info.
Regards,
WOB
