Countrywelder
    Thu Oct 23, 2014 7:45 pm
    Simi Valley, Ca.
A friend gave me the handle and screw assembly to a large vice. The bar is about 1 inch solid with threads in good shape but it was split in half somehow. He asked me if I could weld what appears to me to be a cast material. What to use? DC tig? Settings? Do I need rod for cast material? Would this call for tig brazing and would it be strong enough to hold under pressure? Any suggestion would be appreciated.
Coldman
    Mon Dec 15, 2014 2:16 am
    Oz
Any chance of a pic?
    Thu Jan 24, 2013 12:13 pm
Hard to visualize the job so a picture will help as already mentioned - a vice though can be cast iron or cast steel if it's a better quality one so a spark test to confirm material will help get good answers - both are possible to weld with Tig but you need to know.
Countrywelder
    Simi Valley, Ca.
I will try for some pictures later today. Thanks
It's worth a try to repair it, for the practice and experience.
It sounds to me like the draw-screw is fine, but the cast "arm" of the vise that the screw draws in is broken? If so, I'd vee it out fully, pre-heat the parts in my gas grill to a good 450+, and TIG it up with hi-nickel (old piston rings... Thanks, WerkSpace), and slow-cool it buried in a pile of sand or Vermiculite.
Good luck. This can be done, but it's not usually a beginner weld.
Countrywelder
    Simi Valley, Ca.
Here are the pictures of the vice screw. I'm not sure if that is the right term. Comments please.
Coldman
    Oz
I sincerely hope someone comes up with a solution for you because to me that's a throw away.
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Go the oxy acetylene route and bronze it. Tig brazing is a bit more of an experience thing.
    Wed Aug 06, 2014 12:48 am
    Melbourne, Australia
It's an Acme thread. It definitely won't be cast, but it probably is hardened, looking at the crystalline structure through the fracture point.
Acme threads are quite standard, and you may be able to purchase a length and then just cut and weld the existing handle to the thread, then you don't have to worry about exact matching the thread pitch, which will be a problem.
There are products available on ebay:
http://www.ebay.com.au/sch/i.html?_from ... w&_sacat=0
My suggestion is to replace the thread portion with a new same size diameter and pitch acme thread, even if you have to fabricate a new handle section, bored to the OD size of the thread, insert and bronze weld the two together.
hey_allen
    Thu Mar 05, 2015 6:09 pm
    SW Oklahoma
I have also seen Acme thread rod on McMaster, and you might even be able to source some through a local metal supplier (though that might a bit of a stretch!)
-Josh
Greasy fingered tinkerer.
    Sun Oct 27, 2013 10:57 pm
That's the kind of stuff an old boss used to have me save.
Grind a double bevel, weld it up, re-cut the threads by eye with a hacksaw, file, and cut-off wheel.
It will likely take several hours - but I wasn't getting paid much back then, so the boss didn't care :(
Good luck :D
(if possible, replacing it is the better choice - but doesn't make for a cool story)
    Wed Jan 28, 2015 7:27 pm
    Portugal
May be weldable...
But perhaps you have someone with a lathe nearby? Make a new one.
dirtmidget33
    Tue May 13, 2014 5:22 pm
I would say definitely YES. Reason I know this my brother broke a vise he was beating on handle trying to make it tighter cause thing he was trying to hold kept spinning. Needless to say He broke the threaded acme rod :lol: he wanted to hide it from dad all we had at our disposal to weld it with was a 120volt Lincoln weld pak I just recently bought. (First welder I bought with my own money). I V grooved the rod and using flux core :shock: welded it back together. I hate flux core, I admit it I am a TIG snob :roll: anyway some time with a dremel with abrasive cutting disk to cut threads and it was back together. This was 20 yrs ago that vise is still in use my brother has it now. He don't beat on vise handles anymore with sludge hammers :lol:
Antorcha
    Fri Dec 06, 2013 8:57 am
    By da lake
Measure it up and message these guys
http://stores.ebay.com/imsrv/Lead-Screw ... 4512483011
