Hollywood1
    Mon Feb 23, 2015 9:05 am
    Washington
When welding aluminum I always get a balled end. Is this normal? 30% cleaning, 120 freq. 2% lanthinated sharpened to a point. Welds look great! Machine set at 75 amps. thanks for any help john.
Hollywood1
    Washington
Forgot to mention 1/16th diameter tungsten.
Bill Beauregard
    Thu Jan 24, 2013 9:32 pm
    Green Mountains of Vermont
Is it objectionable? Are you using a machine you can't tweak the settings such as a Diversion? I grind a very blunt point. It produces a narrow arc. bump up one size tungsten if it's a problem.
Hollywood1
    Washington
thermal arc 186 lots of settings. Miller welding video shows a guy sharpening to a point and keeping it like that throughoput the weld.
    Thu Dec 25, 2014 9:25 am
    near Chicago
Hollywood...I have a new Miller Syncrowave 210...inverter... I use 1.5 lanthanated it always balls. It is still relatively sharp but always gets a small ball at the tip. I dont know if its possible to keep a sharp tungsten on AC
Hollywood1
    Washington
here is a picture.
Hollywood1
    Washington
I appreciate the info from everyone. I see people purposely balling the tip on dc but it just happens on ac for me.
    near Chicago
Looks like you got it nailed. I have heard Jody say that he starts with a shap tungsten and let it ball as it may so that what I do and it works great. Jody explains how to ball tungsten on one of his vids but I don't bother. You should see pure ball up on a transformer. Your welds look great!
Hollywood1
    Washington
Thanks for the info exnailpounder. I sure appreciate this forum and the tips from everyone. thanks, John
massacre
    Sat Feb 28, 2015 10:20 pm
    Massachusetts
I have an HTP Invertig 221 and I sharpen to a sharp point also on A/C, usually 3/32 2% Lanthanated and it will form a small ball at the end after a while. As long as the ball stays small and the bead narrow, I just leave it. The arc stays very stable even with slightly balled electrode.
I was using pure tungsten on my Eastwood TIG200, that would end up with a huge ball after a while, unstable arc, bad news lol.
Hollywood1
    Washington
Thanks massacre. I thought I was doing something wrong.
Bill Beauregard
Nothing wrong. Don't let the ball get bigger than the diameter of the tungsten. Set post flow to keep tungsten clean. Consider larger tungsten, and blunt grind. Consider a water cooler & torch, nice anyway, they are smaller. On very clean aluminum you'll do very well as high as 80% EN,
Hollywood1
    Washington
thanks Bill.
Hollywood1
    Washington
I just looked at the tungsten and the ball is the same size as the tungsten and there is no more taper. Should I have blunted the tip more.
Hollywood1
    Washington
Currently welding at over 110 amps with 1/16th. Is this possibly the problem?
Bill Beauregard
I'd go to 3/32.
massacre
    Massachusetts
I usually use 3/32 and set the point either sharp or blunted depending on use?
Hollywood1
    Washington
Ill try a 3/32 and blunt the tip some more. Thanks. John.
    Wed Aug 06, 2014 12:48 am
    Melbourne, Australia
Hollywood1 wrote:thermal arc 186 lots of settings. Miller welding video shows a guy sharpening to a point and keeping it like that throughoput the weld.
Is he welding aluminum in the video?
If I recall correctly, Fronius has a setting for automatically putting a ball on a new tungsten that was specially designed for welding aluminum.
