Raffus
    Tue Dec 30, 2014 4:38 pm
What causes this
Everlast 210 ext.
setup
130 amps
Ac balance 30
Ac frequency (hz) 120
30 scfh argon
Artie F. Emm
    Thu Jul 24, 2014 7:53 am
I'm wondering if your argon flow rate is too high. The Miller welding calculator,
http://www.millerwelds.com/resources/ca ... ulator.php
suggests 17 cfh. I'm not sure that will solve the problem but it will make your bottle last longer. ;)
Dave
aka "RTFM"
    Thu Jan 24, 2013 6:44 am
Yes, much too high. The end of the piece could be causing additional turbulence resulting in what you are seeing in the weld.
