Does anyone quick disconnects for your argon lines? which ones?
This is what I mean
https://www.youtube.com/watch?v=tF8ehISyD2k
Just regular air fittings will work.
Get barb fittings with a 1/4" npt thread, and put them together.
Argon is WAY less pressure then air.
dirtmidget33
- dirtmidget33
Those quick disconnects Oscar posted are GREAT. I installed them on all my torches, they are very reasonably priced easy to install and do not leak. It was because of Oscar posting a pic of his on an earlier thread that I bought some. They solved a concern I had about missing up threads in the future changing torches.
kblenker#22
- kblenker#22
I use the one tec welding makes because they have fittings that go direct to gas fittings no adapters required. For my water cooler I use hydraulic fittings so I don't have to purge the water out when I change torches it takes me about a minute to change torches with no wrenches.
