Yes as you can see from the pictures I posted 0.2mm sheets should be edge welded together both from inside and outside edges.dsmabe wrote:From the original pictures and the video that was posted, I have a question. Are you only having to weld the .2mm material to the thicker material or do you also have to make .2mm to .2mm welds?
Which machine do you mean? The one welds the inside periphery or the one welds outside edges?awill4wd wrote:Another thing is that the machine welding shown in your video is actually plasma welding and I suspect the hand held welding is plasma welding as well. I just couldn't get a close enough look at the head of the hand held torch.
Regards Andrew from Oz.
Anyone else confirms the machine in the video is plasma welding?
I looked around some and the hand welding and the welding if the outside I believe to be plasma. The inside I'm not sure either way but I'm thinking it may possibly be laser welding.
Just welding the thin and thick material isn't too hard I believe. But welding the thin to thin would take some prep.
Getting a plasma or laser welder would be incredibly expensive as far as I know. Tig welding would be possible, but you would need a machine that can go down to 1 or 2 amps.
Mr. Tig on YouTube welded aluminum foil together. The way he done it is the way you would have to do this. Clamp the material intended to be welded where only a fraction of the material is showing. Then when you make your weld, the exposed thin material would be welded in a controlled manner.
To do this, you would probably have to get precision pieces made just to clamp the thin material and act as a heat soak.
I finally went and watched the video. I see nothing at all in that video that a "newb" could do, with any sort of home equipment. Unless you like to tinker with 747 engines or do heart surgery on your kitchen table.
I looked around on YouTube and found the video I was talking about. This is the only way I could see making consistent welds with what you are wanting to do.
https://www.google.com/url?sa=t&source= ... SpzMitP-ug
Im going to try some welds to see if this is even possible with tig, I found some .006 steel that I will try welding together and try welding it to some thicker material to simulate the flange. Hope to try it tonight on the way home.
I anxiously await your results. I have my thoughts on this but will hold off until I see some results.
- TRACKRANGER
I'm keen to see the results too, success or otherwise. Personally I think this will be quite challenging.
......and the results are in! This was definitely a challenge, but I don't know if I proved it possible or not since I didn't make the welds as good as I was hoping.
First I tried grinding a ledge into a piece of 1/4" flat stock. What I found was it took so much heat to try to puddle the steel, as soon as I got close to the .006 steel, it melted away before I could make any weld.
I had some 20ga stainless so I tried again with that, this time I was able to make welds. I actually tried twice because the first wasn't anywhere near what i was hoping for. Surely after the first attempt I could make a solid weld.
Well the second attempt was more controlled but like the first, several spots were blown away. At least one hole because of accidently hitting the foot pedal.
Then on to welding the two thin pieces together. I already knew how I wanted to attempt this, the same way Mr. Tig welded aluminum foil together. I sandwiched two pieces of .006 between aluminum and had 1-2mm sticking out. It left a messy edge but the two pieces are securely welded together.
- 20140929_014733.jpg (34.28 KiB) Viewed 1219 times
- 20140929_014740.jpg (40.31 KiB) Viewed 1219 times
- 20140929_013939.jpg (41.73 KiB) Viewed 1219 times
- TRACKRANGER
Congratulations for making the effort!
What were your settings? I haven't been able to locate anything at work yet except my feeler gauges. Lol I want to give it a shot as well. I'm thinking I could get some pulse settings right to make it work just need some scrap.
I just did some .012" spring steel at 13 amps, I did basket with a piece of bronze
Guys Mr. TIG has shown a nice micro torch in the following video. welding is not anything close to welding 0.2 mm tickness steel sheets but it looks with such a tiny micro torch one can do a lot.
www.youtube.com/watch?v=q0pCir2hmhk
Something to know at these power levels, the HF start may be higher than the welding amps, so it's easy to blow a hole right off the bat.
When fusing wire frame using 0.045 wire, I found that pulsing helped a ton on the thin stuff, and I was working in the 7-amp range. But I also discovered my Everlast 210EXT was set to like 35A for the HF arc start - it was adjustable, but in a hidden menu.
Cheers,
Cheers,
awill4wd
- awill4wd
At about the 4.42 min mark it clearly shows the torch head welding the outside and it's a plasma torch head definitely not Tig.Agoo wrote:Which machine do you mean? The one welds the inside periphery or the one welds outside edges?awill4wd wrote:Another thing is that the machine welding shown in your video is actually plasma welding and I suspect the hand held welding is plasma welding as well. I just couldn't get a close enough look at the head of the hand held torch.
The pic below shows a similar plasma torch head.
We are Tig welders, gravity doesn't worry us.
Miller Dynasty 350
OTC hybrid wave 300 amp inverter Tig at work (Now retired)
Kemppi MLS 2300 inverter, 230 amps of welding brilliance for home use
Miller Dynasty 350
- TRACKRANGER
Andrew, good pickup on the plasma torch.
In addition to the process controlled welding system that is in use, that change in technology gives the subject matter of welding the materials with TIG quite a different direction.
Trev
Trev
