Hello and welcome to forum
Yes there is. Usually AC/DC machines does also have pulsing-function. Pulse can be used basicly anywhere, but mostly it helps on thin plate and pipe for example.
Jody have done at least one video about welding aluminium with pulse.
kmRqaSvcyAU
kmRqaSvcyAU
-Markus-
- TRACKRANGER
One of my machines is a CIGWeld 300 AC/DC. It has pulse for both AC and DC, and has adjustable parameters for pulse width etc. AC pulse can be used successfully on aluminum. I sometimes use this feature myself.jrogers80 wrote:Are there any ac pulsed machines and is ac pulse used by anyone? i see dc pulsed machines but when would ac pulse be used?
From the manual:
The Pulse controls are used primarily to control heat input. Pulse offers a number of advantages as follows:
1) Control puddle – size and fluidity (especially out of position).
2) Increase penetration
3) Travel speed control
4) Better consistent quality
5) Decreased distortion on lighter or thinner materials
Pulse-current provides a system in which the welding current continuously changes between two levels.
During the periods of Peak current, heating and fusion takes place, and during the background (base) current
periods, cooling and solidification take place. Pulse Width is the time in one cycle the current remains at the
peak current setting. Pulse Frequency, measured in Hertz, is the number of cycles per second the current
travels between peak and background current settings.
- 2014-09-18_10-36-46.jpg (68.26 KiB) Viewed 606 times
TwentyFourSeven
- TwentyFourSeven
I just started tig welding thin aluminum a month ago. The machine I bought has an adjustable pulse on it. I tried to use it but found that i am better of controlling the amps with my foot rather than useing the pulse.
Lincoln Precision Tig 225
- TRACKRANGER
Probably once you get the hang of it, the pulse could save you a heap of footwork.TwentyFourSeven wrote:I just started tig welding thin aluminum a month ago. The machine I bought has an adjustable pulse on it. I tried to use it but found that i am better of controlling the amps with my foot rather than useing the pulse.
The pulse on mine still allows me to use the foot control (which I do if/as required)
Pulse is very useful on thin material. You can control the heat input to minimize distortion. It is also very useful when your fit up is not as good as you would like. Using slow pulse rates give you the extra time to shove some filler rod in, and fill the gap on a bad fit up. It is also very useful for out of position welds. If you are doing overhead-it will help you shove filler into the joint, without it falling on your head.jrogers80 wrote:Are there any ac pulsed machines and is ac pulse used by anyone? i see dc pulsed machines but when would ac pulse be used?
