Here a question from a "hobby" TIG welder from the Netherlands.
Recently I bought a new TIG welding machine. At the moment I'm figering out what good settings are, since there are a lot more options than my previous machine had.
Currently my problem is that the welds have a gray collor after welding. In my opinion this means overheating / "surface burning" of the material. The next picture shows an example (as you can see, no external material is added, tubes are 1,5 mm thick, argon backing gas is used).
![Image](https://lh5.googleusercontent.com/-b7sn8qUR3bQ/UhS5E3C5vHI/AAAAAAAAAbM/1Ps1iHd2dZs/s640/2013-08-21%252014.44.55.jpg)
Are there setting which I can change such that the weld shown above looks like the weld shown in the following picture? Such that the weld discolorations are more bright and shiny?
![Image](http://www.tummersplaatbewerking.nl/cms/fotos/0705040854_laswerk-04.jpg)
Extra info: Material used is stainless steel 1,5mm thickness.
Argon about 7 L/min.
Red 2.4 mm thick thungsten bar is used.
Gas lens is used.
Current about 50 to 60 Ampere (reducing the current would be an option, however at the end, the two materials must form one "new" part, good penetration is needed, using a to low amperage this is not the case.
Waiting on your response.
Thanks, Kn3rf
