don't worry about it, it's first class job, it's about 2 years since i welded some alu, if it comes out like yours i'll be pretty happy
p.s. i wouldn't work for somebody who owns a Datsun
damn, i'm wishing for a 911 almost all of my life
about the second class, well u got some end craters that could be nicer
here's a 6g weld I did playn with some pulse setings, 304ss
- Photo0101.jpg (46.23 KiB) Viewed 1652 times
weld looks straight, looks a little hot to me... how thick is that material?
when i weld stainless i will literally do 5 beads and stop postflow and start again after a 30 seconds for cooling. and you have seen my stainless welds
Hey grewru,
Where did you find a hood big enough to fit over that inflated head of yours? Just curious, because your are an average welder at best.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
it's 1,5mm wall , no gap 40A L1 , ~28 L2 , 1,5 sec l1 and 0,2 sec l2.
but that was just training in 6g pos and goofing with pulse. almost never had to weld anything at 45 in a factory, some 800 OD steam pipes ..
inside looks like this
- Photo0106s.JPG (31.06 KiB) Viewed 1455 times
it's not hot at all, the wall is very thin, 1 pass , freehand.gurew wrote:weld looks straight, looks a little hot to me... how thick is that material?
if you stop after 5 beads will take too long to weld one pipe and increase the chance for craters, let's just say it would be luck to pass an xray, some ppl (walkers) make only one stop, but they work on the bench and i get those hanging from a scafold jobs.
i know in the automotive industry, welds with that color would create cracks later on a turbo manifold out of sch40 308 SS pipe, entire wastegate runners would break off etc... i havent had the chance to xray any of my welds but ive yet to have a manifold come back i would think that 1600-1800 degrees under stress of a turbo and pressures from the exhaust pulses would be in the "extreme" category
is dat a known (scientific) fact or something somebody told you? i belive the thikness of the bead has a bigger influence in failure of high heat sistems then a hot(ish) weld, and i've never seen a fully penetrated weld that looks golden on the outside, not on 1,5-2mm ss and not without backpurge
