Deusy
    Thu Jan 09, 2014 9:11 am
Hi, I have a Miller Syncrowave AC/DC that has been welding perfectly. Recently it decided to stop welding. Code 5 came up later 10 then back to 5. In between it works perfectly then cuts out again gong to code fault 5. It has never overheated and each use is short so no possible way to overheat the rectifier. Fans run and water cooling is fine. I am running single phase 240 volts.Any thoughts?
Many thanks, Deusy. Frank United Kingdom.
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
Welcome to the site Deusy.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
I don't recall those fault codes off the top of my head. I'll try to remember to check the manual tomorrow at work.
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Hey mate,
Send an email to miller tech support. I hear they are top notch.
