karlevo8
    Mon Aug 23, 2010 7:28 pm
problem solved :D
johnnywgk
    Sun May 02, 2010 8:52 am
sounds like you got your torch pugged in the [+] positive, if you have, change it to the [-] negative. i think i a right here.
karlevo8
johnnywgk wrote:sounds like you got your torch pugged in the [+] positive, if you have, change it to the [-] negative. i think i a right here.
fair point ill go and check but think there right way round would be good if it was that simple that
karlevo8
all solved thanks for the ideas
