rahtreelimbs
- rahtreelimbs
I am welding for the 4thy timewith my Miller EconoTIG and I am getting shocked. I am welding stainless steel on a welding table that I recently made. I am wearing the proper welding coat and thicker than normal gloves but I am still recieving some shocks. What is wrong???
- admin
- Site Admin
i am not an electrician, but the instruction manual probably has a step for driving a copper rod in the ground to make sure the frame of the machine is properly grounded to prevent high frequency from bleeding out everywhere... that might be the problem.
Make sure you are not between your ground and workpiece. Or if you can ground right to the work . Also to narrow it down try wearing a pair of the latex gloves under your reg gloves.Sometimes you can get a jolt from just a hole around the stitching as well in the fingers of the gloves.
Hope this helps
Gary
Hope this helps
Gary
Everlast 250EX Tig
Everlast torch cooler
Everlast 50P Plasma Cutter
Home Built 2 x 4 CNC Router table
Shoptask Bridgemill with CNC added
Central Tools 7" Bandsaw
