w31der
    Sun May 26, 2013 7:34 am
I finally got to try some tig welding, stared off welding on these 1 inch 2mm thick pieces and then moved to some thin wall tubing, which was alot move enjoyable to weld.
Alexa
    Mon Dec 31, 2012 10:07 am
Welder.
As the months pass, you will probably have a chuckle looking back at the first weld.
As with all processes, the restarts, tie-ing in to the end of the last bead, are important to develop the techniques.
Tanks for sharing the photo.
Curiosity ... what is the white-ish background behind your weldment in the photo?
Alexa
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Hey,
Im guessing this is not you first weld ever, merely your first tig. good effort, keep up the good stuff. And dont mess up the carpet.
That's not bad at all for a first effort at TIG. The shadow lines suggest very little distortion.
Alexa must have tile floors... ;)
fisher
    Thu Jan 24, 2013 3:34 am
Very good start to your TIG, but the lounge room floor is perhaps not the best place to practice ;)
w31der
Back to night class this week for another go at tig welding, thought i might try some filet welds this time.
That fillet is either too hot, or bad gas coverage.
A fillet traps gas better than a groove, and should show better color than that.
Technique-wise, there's nothing wrong with it I can easily see.
If you have too much angle between the torch and the work, you can draw air in and discolor the weld. It's also possible to have a line-leak in the gas, or even bad gas.
That weld should be shiny/blue.
It may also be bad camera angle, in which case, ingnore me.
TamJeff
    Tue Dec 04, 2012 4:46 am
Nice for a first. I added 'hardener' to my first, in a few places.
w31der
Lucky enough to get a job welding stainless.
Dragging the cup
Dragging the cup
w31der
first photo was me dragging the cup, I haven't tryed walking the cup before and I am lucky to have experienced guys showing me how its done. Seem to get better consistent results, hopefully i can post up the purge pipe in the future as im still working on that.
walking the cup
walking the cup
w31der wrote:Lucky enough to get a job welding stainless.
Congratulations!
Jonty_B
    Thu Oct 02, 2014 12:09 pm
Otto Nobedder wrote:That fillet is either too hot, or bad gas coverage.
On that particular weld I'd have guessed at it just being very dirty MS with a lot of carbon, I keep arguing at work with a guy who refuses to even contemplate taking it off first.
Those stainless pieces are looking very nice though :D
w31der
first time doing this, I couldn't cap it off
1662612_10152586684714807_6325654604614480813_n (1).jpg (139.95 KiB) Viewed 674 times
w31der
second
w31der
I could figure out if i was trying to fill to much, I tried 2mm wire and 2.5mm wire. it didn't come out to nice.
    Australia; Victoria
Hey,
Maybe trying to fill it too quickly, looks pretty thick. Don't cap until its just below flush. More quick passes to keep the heat input down.
w31der,
We tend to be our own worst critics.
Frankly, that doesn't look bad at all. I don't see flaws, such as undercut or an excessive HAZ.
I'd expect it to be a solid weld and pass "bend".
The sharp edges I see from one "weave" to the next suggest you could carry more heat in the cap. This will help it to "wet in" and lay down a bit smoother.
Practice, practice, practice. One day you'll be amazed that you ever thought it was hard. And then you'll try something new, and start from here again... :roll:
