bulletbusiness
- bulletbusiness
Just a newbie with Tig but thought the amp display on my machine would change as I fluctuate the pedal depression? Mine continues to display the amperage I selected prior to starting. Normal?
bulletbusiness
- bulletbusiness
If it doesn’t have that, then does your amperage vary at the torch with more or less pedal depressed? Set the amperage to 150, then only depress the pedal a small amount. Is the arc strength behaving correctly?
I don’t have that machine so I’m asking some routine questions. If the display isn’t changing it may simply be a lack of feature to show the dynamic amperage used. As long as the pedal is controlling the arc, I’m not sure why you care because you can’t weld and watch the machine simultaneously
bulletbusiness
- bulletbusiness
Im pretty sure the amperage is changing as the pedal is changed-just thought some machines show what is being used and it didn't seem like this lincoln ever changed the display
