TimB
    Sun Feb 09, 2020 12:16 pm
I have owned my Lincoln Idealarc for about 13 years, but just recently got set up to use the TIG (been using for stick welding).
I am using the gas regulator that came with welder.
The regulator leaks argon constantly from the holes on the regulator head.
Is this the way it works, or do I need to repair or replace the regulator?
Thanks,
This forum and TIG are new to me. Looking forward to learning!
I would have written a shorter essay had I had more time.
cwby
    Wed Nov 13, 2019 7:07 pm
Sounds like the diaphram is rotted. Shouldn't leak anywhere.
clavius
    Wed Sep 21, 2016 9:32 pm
    NE Massachusetts
cwby wrote:Sounds like the diaphram is rotted. Shouldn't leak anywhere.
I'll second that. You need a new regulator.
TimB
Thanks Guys,
I bought a new regulator. When I have some time I will take the other apart to see what is up, and whether it might be worth fixing if parts are available.
