I bought a CK 17 super flex torch and a Dinse 35 connector from CK for a Everlast 210EXT and the 35mm dinse is incorrect. I bought the SL2-35 and it is different than the end from everlast. Anyone know where one can be bought from and or the correct part number to order for my new torch. I cant post a picture of the connector. Too much of a noob to the forum
Thanks in advance,
Joe
The connector does go in the welder and does twist to lock. The everlast brass end is solid but the ck dinse has a hole thru it. I was aware of the gas end fitting end on ck is threaded and was going to machine a quick release fitting to adapt to the weld unit. I did notice the dinse on ck a 1/8 in longer. I away fro shop now so cant do any testing tonite
Mine has a hole through it too. As long as it twists and locks it should work. Same torch and connector setup on my 250EX and it works.
I just pulled the quick disconnect off the stock torch and put it on the CK connector. I only have 1" brass stock so I was too lazy to machine a fitting.
"Your welds should sound like bacon. If your welds smell like bacon, you're on fire." - Uncle Bumblefuck (AvE)
Is there a certain numbers of posts that have to be met by a poster before we can post pictures? The up load icon is not showing up when I post. I have searched the How to use the forum and only see that a file size max of 256kb.
Joe
Joe
I'm not terribly familiar with your machine, but, your gas fitting (Dinse connector) does not need a hole in it since you have a separate gas fitting.
http://weldfabulous.com/welding/tig/con ... ory_page=1
As for the length of the male Dinse, did you spin the collar loose enough to twist the male first? The collar tightens the connector after the twist-lock. I use a similar fitting on my Dynasty, and have purchased the SuperFlex cables for it and my Multimatic and both fit perfectly. They are listed as 35mm and 25mm Dinse respectively.
I'm using the forums on my phone so it may be different, but it's at the bottom of the text input field.JoeM wrote:Is there a certain numbers of posts that have to be met by a poster before we can post pictures? The up load icon is not showing up when I post. I have searched the How to use the forum and only see that a file size max of 256kb.
Joe
Upload attachment tab, choose file then upload. Next to options.
I think the hole is in the connector just for ease of machining. Why make 2 parts when one works for both.
I will take some pictures of my torch when i get home. its a ck 17 and the dinse connector has hole on the end as well. Its no big deal as long as the connector with the gas hose on it is solid. i will show you what mine looks like and you can compare.
Attaching a picture of the economy torch end and the CK end. The CK is around .125 longer and the lock pin is located in a different location. The CK does lock in but is loose when fully inserted and turned. I did what cj737 posted and spun the plastic collar to lock it securely in the welder. Still need to make the 9mm quick connector before I can use the new 17 torch. Thanks for all the replys guys.
Joe
Joe
- dinse connector2 JPG.JPG (52.67 KiB) Viewed 3313 times
Looks like you got an SL2-35M instead of an SL2-35. Look at this page http://www.ckworldwide.com/dinse-gas-cooled.html
I've got a 210EXT as well, but I got my torches from Everlast. I did make up an extension for the ground and had no problem with the connectors for that.
David
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
Everlast 210 EXT
Lincoln AC225
Lotos LTP5000D
Oxy-Acetylene
He said it's blocked off and has the external gas hose so it's not that.dgapilot wrote:Looks like you got an SL2-35M instead of an SL2-35. Look at this page http://www.ckworldwide.com/dinse-gas-cooled.html
It's the same with mine. Mine snugs up after about 270* of a turn.
- 20180514_223909.jpg (48.6 KiB) Viewed 3292 times
The copper sleve in the Everlast looks to be bonded in. Or is it threaded, I don't want to break it off as I wont have a torch to use.
Forum will only let me post one picture at a time.
Joe
- IMG_1415.JPG (52.67 KiB) Viewed 3284 times
Joe
No it's not wrong..... as long as the connector under the dinse connector that connects to the cable is solid and not a flow through style it will be fine. I know this because mine is the exact same thing.cj737 wrote:Your SuperFlex Dinse is the wrong model. Simple as that. You can swap the unit from your left hand to the SuperFlex and be done with it.
