I have a winch and the drum and clutch engagement dogs have become rounded off. I would like to build it back up and machine it back to original. Do I need a special rod for hardfacing or will ER70S6 work? I would appreciate your input.
Hi there,
In applications of reclaiming steel, besides going full science on the whole thing, Stainless steel filler 309 is good. It is meant for welding on steels,312 stainless is better but its not as common, and provides a slightly harder deposit. I don't know exactly about your part, Maybe it needs a higher alloy if its really hard. Jody talks about Hastalloy W but I doubt you could find a single rod of that laying around.
You can if you wander over to my house.weldin mike 27 wrote:Jody talks about Hastalloy W but I doubt you could find a single rod of that laying around.
If you squint your eyes real hard, partially cross them, and focus behind this picture, you just might spot some...
Not responsible for eye doctor bills, lol.
So, the question is, are you going to sell some to him, or are you just going to be a good guy and give some. A good friend on here was supposed to send me some silicon bronze once in exchange for some files but never got around to it. Ah well, Que Sera Sera.
I can already imagine you digging through piles and piles of 'exotic' filler wire just to find a bit of 'plain ole' ER70..Oscar wrote:If you squint your eyes real hard, partially cross them, and focus behind this picture, you just might spot some...
Bye, Arno.
I think I can spare a rod if he really needs it. With as much nickel as W-alloy has, I'm not sure it would be the best bet for something that requires a hard surface. Nickel usually makes things stretchier.weldin mike 27 wrote:So, the question is, are you going to sell some to him, or are you just going to be a good guy and give some. A good friend on here was supposed to send me some silicon bronze once in exchange for some files but never got around to it. Ah well, Que Sera Sera.
kiwi2wheels
- kiwi2wheels
Would some 1/16" or 3/32" hard facing stick rods be an option ? Polish after flux is removed.
Cheaper and easier to obtain without breaking the bank.
Bill Beauregard
- Bill Beauregard
I have SMAW rods of manganese component. They work harden, seem bullet proof, and I'd contribute to the experiment if you like. Without this discussion I'd say strength, ductility, and impact tolerance are more important than hardness. I'd use Hastelloy. I have some in small diameters. Wanna try some? Otherwise I'd go 309, or 312 stainless.
Try to lure Jody out of his lair. He will know.
