Lynch881
    Thu Dec 14, 2017 6:00 pm
    Massachusetts
Can anyone help me out with there thought on welding a 3 inch puncture on a 5 gallon metal gas can. What I could do to weld it fixed. After it is thoroughly cleaned out of course. Can I grind it a tig weld it? Any advise is appreciated thank you.
Gas can that’s had gas in it?
How would you clean this? Even so an argon purge would be required.
MarkL
    Wed Jun 15, 2016 7:09 pm
    Far west Chicago burbs
You could solder it, that's probably how the can is made if it's very old. If you tig on it you'll get it too hot and the can's joints may get hot enough to flow the solder. Soup cans used to work well as a patch for this kind of repair because they were made out of tin. I'm not sure what cans are made of these days, you'd probably have to experiment to find a patch material.
Lincoln Square Wave 200
Lincoln 225 AC/DC
Harris Oxy/Acetylene torch
I once new an old guy who went to weld on an old water tank. Turns out 20 Year’s before it was a fuel tank. Was the last mistake he made! He’d done work on lots of old fuel tanks. That one was no big deal. It was a closed casket.
Lynch881
    Massachusetts
Hey guys thatnks for the replies. The gas cab is one of the brand new eagle brand red metal cans. It just has a little slice in it. I was hoping to just be able to fill in with rod. It’s. It that big where a patch is needed. I will post a pic of it this week when I grab it from work. I would clean it by flushing it with hot soapy water thouroughly an then I’ve seen guys stick a rag in it an light it an if it does t go boom your good to weld.
mcostello
    Thu Jul 07, 2011 10:21 am
    lancaster,ohio
Seal-All is a sealer that might work well.
    Sun Sep 22, 2013 10:14 am
    Minneapolis Mn 55407
Hose,car exhaust(carbon monoxide)(its inert)Let it run
Works for me.
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
