doleslie
- doleslie
Here is the front and back of a weld. I'm concerned about the back side of the weld. Please observe and comment.
Using mild steel 18 gauge with a 9 torch 1/16" electrode.
Thanks,
Dennis
- The other side has been reversed to match the front.
- 2017-10-19 14.43.31.jpg (29.06 KiB) Viewed 675 times
Dennis Leslie
Prescott Valley, AZ
Newerbie
Prescott Valley, AZ
Newerbie
doleslie
- doleslie
I was using 1/16" rod. I do have some .045". I'll give that a try. By the way, I was using 67 amps. You have addressed my problem area. Thanks
Dennis
p.s.
I have done a similar weld on 11 ga (.122") and here are pictures of both sides. This joint material is 2.5 times the thickness. I used 100 amps with a 3/32" electrode and 1/16" filler rod.
Dennis
p.s.
- Back side of weld
- 2017-10-22 14.14.23.jpg (63.41 KiB) Viewed 567 times
- 20171022_141335.jpg (68.89 KiB) Viewed 567 times
Dennis Leslie
Prescott Valley, AZ
Newerbie
Prescott Valley, AZ
Newerbie
