plain ol Bill
    Wed Apr 08, 2015 6:46 pm
    Tenino, WA
This tip not for use during a test - when testing never re-start a rod.
When using 7018 while bench welding keep a chunk of 2X4 sitting on the bench. When you break the arc tap the rod on the 2X4 a couple of times. It will start easily when you start to re-use it.
Tired old welder
CNC plasma cutter
Colorful shop w/
C7Z
  • C7Z
  • New Member
    Thu Apr 24, 2014 3:41 pm
    Arizona
Also see the video below, 2 more tips that make for easy 7018 restarts. One at 2:45 and another at 10:00
https://youtu.be/eNs078TVZU0
Dynasty 200DX
MM252
Powermax 45
VTS 450/460 Oxy-Acetylene
VincenzioVonHook
    Sat Nov 07, 2015 8:35 pm
i use the good old flick at the end of a run. Looks boss, but can take out eyes if around other people. Luckily I work alone most of the time.
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
Welcome to the forum C7Z.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
