need advice 1104 down hill procedure for pipe welding
Posted: Tue Aug 18, 2015 5:05 pm
by BradlyD903
can anyone give me advice for down hill welding with 1104 down hill stick welding + Amps "heat" for each specific rod used from a 6010 1/8 - 5/32" and 3mm for underground pipe with a bead layout diagram for stacking welds from root-fill & cap?
help needed.
I'm a up hill lo-high welder have been for several years, looking to take a test for a standard down hill procedure. I Dont have the rods to use or someone to give me a clue.
Re: need advice 1104 down hill procedure for pipe welding
Posted: Wed Aug 19, 2015 5:52 pm
Bradley, I could talk a little bit on the finer points of downhill welding, but I've never been a "downhill all the way out" guy. Roots, only. That's because I'm accustomed to AWS and ASME codes, and have never read the API 1104 standard.
I'll see if I can dig up some excerpts or get my hands on an outdated copy, so we can establish what you might find on a WPS for an API 1104 test (which will generally be tighter in tolerance than individual procedures on actual jobs). If it falls in the range of skills of any members here, we'll have a starting point for some useful advice.
In the meantime, do a google search for API 1104 videos, and you might find some instructive YouTube stuff.
Posted: Wed Aug 19, 2015 5:57 pm
by BradlyD903
Thank you, I can run a bead and hotpass without a problem. I've just never filled and caped down hill.
Posted: Wed Aug 19, 2015 6:42 pm
BradlyD903 wrote:Thank you, I can run a bead and hotpass without a problem. I've just never filled and caped down hill.
You're welcome.
I'm in that same classification. I'll see what I can come up with.
I'll also copy this topic into the SMAW section, since not everyone scrolls down this far...
Posted: Thu Aug 20, 2015 12:40 am
by forrestderp
For 5/32 7010 I run in 3rd gear and 60-65 on the fine on my sa200. probably around 140 amps
Heres a cap I did with 7010 on 3" with that setting.
