7018 vertical down
Posted: Wed May 14, 2014 8:51 pm
by kermdawg
Is this possible? I never realized I hadn't done it before. Tried it last night with crappy results. Everything I tried, every heat I tried...nothing ran well.
Re: 7018 vertical down
Posted: Wed May 14, 2014 8:57 pm
by Shield Arc
It's been years, but I have done it. You have to be ready to flick the slag puddle out of your way. Then jump back into position to continue the weld.
I live in a county that has three Navy shipyards, over the years several welders in these yards have told me the Navy has a procedure for 7018 vertical down hill.
Posted: Wed May 14, 2014 10:26 pm
by AKweldshop
Sounds like crap!!!!
Posted: Wed May 14, 2014 10:33 pm
I'd think the extreme challenge of it (staying ahead of the slag and keeping inclusions out of the weld) would make it inefficient compared to a xx10 downhill and/or xx18 up.
I'm sure it "can" be done. This does not mean it "should" be done.
Posted: Wed May 14, 2014 10:57 pm
by Superiorwelding
I actually tried it the other day on 30" pipe. Lets just say I need more practice and really once you cleaned the weld up it didn't look all that bad. The slag is a killer. I didn't think of flicking the slag out of the way. I will have to try it more in the future. I to have heard of procedures for 7018 vertical down. Hence the reason I was giving it a shot.
Posted: Thu May 15, 2014 3:55 am
by wheresmejumper
There is a 7018 rod ive heard about designed for vertical down, cant remember the name as its been a while
Posted: Thu May 15, 2014 5:55 pm
by rake
7018 downhill is a waste of time. You will trap more slag than you'll deposit weld metal
Wanna run vertical down? Get some 6010 or 6011.
Try the right rod for the right job.
Posted: Thu May 15, 2014 6:08 pm
by kermdawg
kermdawg wrote:Is this possible?
rake wrote:7018 downhill is a waste of time. You will trap more slag than you'll deposit weld metal
It was just a question :/
Posted: Thu May 15, 2014 7:28 pm
by Antorcha
wheresmejumper wrote:There is a 7018 rod ive heard about designed for vertical down, cant remember the name as its been a while
It's called 7014.
Posted: Thu May 15, 2014 9:15 pm
by MinnesotaDave
Here are three 7018 electrodes from Lincoln that claimed vertical down:
(The bottom of each pic shows positions)
- image.jpg (37.9 KiB) Viewed 6465 times
- image.jpg (36.61 KiB) Viewed 6465 times
- image.jpg (38.87 KiB) Viewed 6465 times
Posted: Sat May 17, 2014 6:10 am
by wheresmejumper
10045 is the low hy electrode for downhill I had heard of
lincoln pipeliner lh-d100
http://www.lincolnelectric.com/en-us/Co ... nElectric)
Posted: Wed May 21, 2014 10:51 pm
by nickn372
It can be done. I have done it but only by request. You need to run 10-15 amps hot at least and run a slight push down angle. Also do a back step pattern. This will allow you to keep the steel ahead of your weld as clean as possible while you travel down and use the push angle and arc force to drip away the extra slag. To me it defeats the purpose of using 7018s. Why not 7010s but again I only do it by request of another welder that I sometimes help out.
Posted: Thu May 22, 2014 10:18 am
by shawnmac
Have heard of it being done on Pipeline
Posted: Thu Jun 26, 2014 11:21 pm
by EpicInvasion714
My welding instructor said it is possible but said you have to in a sad face kinda of pattern and that you have to be fast otherwise you will burn through and that as you are welding you see the junk falling down from the previous one
Sent from my SGH-T999 using Tapatalk
Posted: Sun Jun 29, 2014 11:40 pm
by Joejoe8455
I've only used 7018 downhill for thin metal never heard of doing it for any structural type welding, seems like going up hill would make for better results anyways
Posted: Wed Jul 02, 2014 9:34 pm
by EpicInvasion714
Im currently learning vertical up 7018 and my instructor says that is what you use most of the time in thw field. I don't know if it is true or not
Posted: Tue Oct 28, 2014 7:39 am
by JerryWilliams
You have to run the rod slowly. run your heat just like you would for flat and burn slow enough to boil the slag out of the puddle. If you watch the puddle you'll see the slag try to run down. In a way this helps cuz the only way i found to counteract it was to whip back to the center of the weld and do a little circle to push it back and boil it out. This gives better penetration at the root of the joint and then just continue to whip it back and forth like normal vertical. My dad taught me this trick welding on logging truck trailers. We had alot to build and nothing but 7018 to do it with. I argued with him that 7018 wasnt a downhill rod til he showed me and after 2 practice passes i had it down. Those trailers still hauling heavy loads every day and aint broke yet
