jrjensen
    Tue Apr 29, 2014 9:00 am
    Wasilla, AK
I've been mig welding for about a year now and finally decided I want to learn to stick weld. It's not something I'll likely use everyday, but it would be nice to be able to add it to the résumé if I needed to. Luckily I have good equipment and an endless supply of scraps and rod to learn with.
My supervisor at work is a pipe welder and he was welding up a pipe the other day so I started quizzing him on things. He gave me some basic advice and said I could practice all I wanted so I just gave it a shot. These are some pics of my first root pass. I did practice on some plate for a day or so before trying pipe so these aren't my first ever stick beads. I'm running 1/8" 6010 at 75 amps on a Lincoln precision tig 275. I'm welding 6" sch 40 in the 5g position with a 3/32" root gap.
It looks to me like my root pass has just about filled up my gap in the first pass. I'm guessing that's because I ground my bevels too steep, but maybe you guys could give me some input on that. There's also a couple spots where I can see on the inside of the pipe that I didn't quite get enough penetration. Any advice for me on getting better at this? Is there anything you see that I should work on?
Antorcha
    Fri Dec 06, 2013 8:57 am
    By da lake
Too cold.Run it at 105-115 and shorten the "whip" A swirl is a more accurate depiction. It's not even a swirl. Pretend you have Parkinsons. It's a "jitter", nothing more.
The drag and whip terminology is really BS.
Drag does NOT mean drag. It means nearly zero arc length. Thousanths.
Whip means stir the pot a little. You aren't spanking the Vienna. Verdad ?
DylanWelds
    Tue Feb 25, 2014 3:25 am
    Washington
75 sounds better than 105-115 to start.. that is really on the high end for an open root weld with a 3/32 gap. My thoughts are that since you say your not getting much penetration on the inside your just building up on the outside. I jam my rod in there tight so I can barely see the arc but can tell the inside of the pipe is lit up and just watch my puddle from the outside. I like to just drag it up with a sort of very slight zig zag motion to make sure I'm tying into both sides enough as I'm traveling.
jrjensen
    Wasilla, AK
Thanks for the tips. The high spots are where I started to keyhole out of control and tried whipping it a lot farther forward and bring it back to try and get it to cool. It kept me from blowing a hole in it, but I ended up with a few high spots from it. I still think my biggest problem was having too steep of a bevel in it. Our WPS for welding an open root butt on carbon pipe here at work states 1/16"-1/8" root gap so I think 3/32" gap is pretty much right where I want it. I suppose I could tighten it up, but I didn't have anything that thin to lay between the two pipes to keep it spaced evenly while I tacked it.
