More overhead trouble
Posted: Thu May 02, 2013 9:06 am
Trying to add side rails to my Jeep. The rails are 3/16"
Been trying to weld to body sheet metal.
I have an old inductor Marquette A/C box (pick current by moving the lead position to a different hole).
I have tried 6013 3/32, 1/8 7018 1/8 at different current settings, rod angle etc. Seems to melt the sheet metal no matter what I do.
It is held in place due to the ends have thicker metal to weld to but would really like to make it airtight as this will keep out future corrosion from road salt.
I have some 1/16 7018 on order and can get 1/16 6013 locally but last time I tried it always stuck.
Any ideas?
For flat welding I ran a large puddle of 7018 at 100 amps and short arc and pushed the puddle into the sheet metal with ok success but was left with the large puddle to grind flat (its the step). I even tried some brazing rod but the arc still melted the sheet metal as the braze puddle froze too fast if I kept the arc away from the sheet metal .
Any ideas?
