I am new to SMAW also. things i have picked up on is that 7018 is probably the nicest to weld with. way nicer then that 6010 crap.
i prefer DCEP or reverse polarity as it puts more heat into the workpiece and is a more controlable arc.
also, pick your amperage correctly. 7018 or 7014 (if you dont have an oven) the amps is easy to find out. say 1/8" rod, .125" X 1000 = 125 amps. its a great starting point. for the 6010, assume one smaller size. 1/8"=3/32" therefor around 90amps. its not perfect, but its a great place to start.
also maintain about 10deg back hand... or pull.... it will give deep penitration and ya, enough said
get some 7014 1/8" and play dude! 7014 does not need much manipulation (circles, weaves, etc.) but i like to move and pause technique. do not be affraid to close that arc gap, remember to strike, stabilize, build (get material build up and hot, to eliminate porosity), move, and pause at the end for a moment, then brake the arc fast!
best advice is to get some seat time, 3/8" cold rolled plate 6"X8" and stack beads.
oh and use both hands and get comfortable.
