7018 slag control
Posted: Sat Nov 09, 2019 5:36 am
by WelderDan
I'm gonna try 7018. I've gotten pretty good at using 6013 and 7014. Should I use a steep rod angle to control slag, or is slag not a big problem with 7018?
Re: 7018 slag control
Posted: Sat Nov 09, 2019 7:40 am
by Coldman
No. Keep a drag angle 0-10degrees. Tight arc is essential. Flick the flux off the end of the rod with your gloved thumb for restarts.
Posted: Sat Nov 09, 2019 3:48 pm
by WelderDan
thx
Posted: Sat Nov 09, 2019 3:59 pm
by E T
I use a file to get the slag of the end of the rod for restarts.
Using your gloved thumb rips the leather and before you know it you use your skin to get the slag of.
My gloves last a lot longer since i started using the file.
Posted: Sat Nov 09, 2019 6:38 pm
by Coldman
Using a file is fine for the weekend wars. If you're doing it on the job you haven't got time to screw around with files and besides your gloves get destroyed by grinder action, sharp burrs and burned way before flux flicking makes a difference.
Posted: Sat Nov 09, 2019 6:43 pm
by Coldman
If you're cutting up your gloves with flux you're doing it wrong. It's more of a squeeze than a scrape. You don't need a full end clean, you just need to expose metal in one spot so you can strike an arc.
Posted: Sat Nov 09, 2019 8:44 pm
I use a file and a wire brush. Rods cheap. I don’t relite on anything important everything else gets tapped on my file or a nearby hard ungrounded surface. Just a matter of habit.
Posted: Sun Nov 10, 2019 7:52 am
Poland308 wrote:Rods cheap. I don’t relite on anything important everything else gets tapped on my file or a nearby hard ungrounded surface. Just a matter of habit.
And its a GOOD habit too. Anything x-rayed deserves fresh rods for every restart. A few rods are far cheaper than grinding or cutting out a failed weld.
Posted: Wed Nov 13, 2019 4:04 am
by WelderDan
After jackin around a bit I finally started getting nice looking beads and "peelers."..with the 7018
They are Lincoln 3/32. It says to use 65-100 amps, but I couldn't get a stable arc on 1/4 plate steel unless I turned up to 120 amps. 100 amps seemed week. 110 was a little better, but 120 seemed to be the sweet spot.
Is it common to have to turn the amps up out of spec to get a stable arc? The pics I attached are 120 amp beads on 1/4 steel.
My machine is a Sungold arc200
Posted: Wed Nov 13, 2019 6:26 am
by BillE.Dee
I seem to be likin that weld Dan. I think that the machines of today are only in the ball park of getting the settings. I really don't know if they are all "tuned" to be the same when set at a particular number on the dial. I think it is all what works for YOU.
Stay safe, warm and healthy.
Posted: Wed Nov 13, 2019 6:16 pm
by WelderDan
Thx BillE... Good point about the machine amp dial too. My little inverter didn't run 6010 or 6011 very well on the recommend amp range, per the dial setting. Perhaps if I kick the amps up on the dial I'll have better luck... Going to try it..
Posted: Thu Nov 14, 2019 8:48 am
Could just be a calibration issue with the machine. With 3/32" Lincoln Excalibur 7018, ive used 75-95 with perfect results.
Posted: Thu Nov 14, 2019 10:05 am
by 77cruiser
My miller Dialarc like about 115 amps for 3/32 7018, won't hardly run them at less than 95.
Tap the rod on the concrete floor when it's still hot, works pretty good for restarts.
Posted: Fri Nov 15, 2019 10:05 pm
by WelderDan
Well I can make some nice 7018 beads on a flat surface but my 7018 fillet welds are ugly. Getting slag inclusions.
I think I need to run hotter.
Posted: Sun Nov 17, 2019 9:40 pm
by snoeproe
Never had to use anything over 100 amps for 3/32 7018.
My idealarc 250 likes 85-95 amps on DC+ polarity for flat welding. For vertical up, I’ll run 80-85 amps.
