nsw
  • nsw
  • New Member
    Fri Nov 17, 2017 3:32 am
Found a pice of pipe 23x100mm that just wanted to be welded. This was in hlo45 (6g). With 7018 dcep. I run a 2mm rod in the root. And a hot pass with 2.5mm after this I run 14 passes with 3.2mm. Really good practice that will keep you entertained for a while.
Artie F. Emm
    Thu Jul 24, 2014 7:53 am
Dang, that is one heavy chunk of pipe. And the saw that cut it is no slouch either.
Dave
aka "RTFM"
Coldman
    Mon Dec 15, 2014 2:16 am
    Oz
Wow. Looks like about 20 fill passes to me.
Sent using Tapatalk
Coldman
    Oz
Actually the surface of the welds look like wire brushed surface rust. Are you sure you did this yourself?
Sent using Tapatalk
nsw
  • nsw
  • New Member
Coldman wrote:Actually the surface of the welds look like wire brushed surface rust. Are you sure you did this yourself?
Sent using Tapatalk
U are funny, I think it was me. It starts to rust quite fast when you clean it with alcohol, acid and hot water.
Coldman
    Oz
[quote="nsw"][quote="Coldman"]Actually the surface of the welds look like wire brushed surface rust. Are you sure you did this yourself?
They will do that
Sent using Tapatalk
