So 6010s won't run on most inverter based machines.
But why?
Thanks in advance for your help!
I am 90% sure it is due to a low operating voltage. But honestly for anyone not pipe welding, 6011 ought to do most everything a 6010 does. Here are the specs from Lincoln. It seems awfully darn close to me.
- 6011 vs 6010 5p+.jpg (58.3 KiB) Viewed 3941 times
Multimatic 255
I believe it should be some inverters won't run them.JHenze646 wrote:So 6010s won't run on most inverter based machines.
But why?
The ones I have now all run them fine.
I had a miller maxstar 150s that would not run them, or just barely if the arc was super tight.
Miller said it just wasn't designed to.
- Farmwelding
Inverters with arc force or dig settings will run them fine. They arc force or dig just adds a little voltage sometime to keep the rod going.
It's more like: most small, home hobby type stick/TIG inverter machines won't run 6010. Of course there are exceptions like the ESAB 161. It fits the description above, but does run 6010. Once you get into the $1500+ stick/TIG machines then the likelihood of being able to run 6010 increases substantially. If you're playing around with $100-$300 mickey mouse welders, then you'll get frustrated very quickly.JHenze646 wrote:So 6010s won't run on most inverter based machines.
But why?
My Everlast Power arc200 has an extra positive port for 6010. It's supposedly higher inbuilt arcforce or something. 6010s are not very popular to joe pinchpail off the the street over here.
Thank you all for the replies. I am a self-learning hobbyist so please excuse my lack of knowledge.
I was wondering what 6010s required differently in electric output and what causes it(composition?).
I have no idea what the correct terms are so thank you for your help.
ryanjames170
- ryanjames170
My AHP 160ST will run 6010 to some degree how ever it takes a tight arc and the pentration is not as good. how ever my everlast 200ST will run 6010 very well. infact good enough to see them to cut steel. the main thing is that a inverter needs to be made to run E6010 and it also needs a good power source to run them good.. IE no long extension cords on 110V or it needs to run off 220V
Welder/Fitter
RM Fab & Products
Lincoln Invertec V300 pro
Miller 54D Wire Feeder
Miller 2E DC Welder Generator
Everlast Power IMIG 200
Everlast Power ARC 200ST
RM Fab & Products
- Farmwelding
Hey... I would rather oh ask any question that you think is stupid because it helps you learn and could prevent future problems.JHenze646 wrote:Thank you all for the replies. I am a self-learning hobbyist so please excuse my lack of knowledge.
- Farmwelding
With that kind of schedule you must get quadruple time and a half for anything over 90 hours a week.Oscar wrote:Yes, it will run it all day, 28 hrs a day, 9 days a week, 383 days a year.motox wrote:Oscar will your HTP run 6010?
Popeye the old miner
- Popeye the old miner
6P?...What is that?...8010? How did they come up with 5p designation and such anyway? Just curious
I love running stick on my Syncrowave. I actually like it just as much as a Lincoln Idealarc round top, that I got to try once.i haven't done stick with my HTP only my syncorwave transformer machine.
Multimatic 255
