cashiusclay97
- cashiusclay97
Is a Miller Thunderbolt ac/dc SMAW machine a Solid investment? I found one used for 300 is that a good deal Thanks!
They will last you a long time. As for $300, depends on how old it is. Check ebay. Here is one.
http://cgi.ebay.com/miller-225-thunderb ... 736f6#shId
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
cashiusclay97
- cashiusclay97
cashiusclay97
- cashiusclay97
Im buying a miller 225 ac/dc smaw machine. Can it weld 1/2in low to medium carbon steel to 1/2in mild steel in one pass with a 1/8 rod? Thanks!
There is a little more to it than that. To answer your question as it is, the answer is no. What exactly are you trying to weld? What are you fabricating and what will it be used for?
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
kermdawg
- kermdawg
Can it? Sure. Wont get much penetration, but it can melt 2 pieces of 1/2 inch steel together, maybe 1/8" deep, if your lucky. Definately wanna try for some bigger rod if your gonna be doin that thick a metal. Should be able to run 5/32 on that machine, not sure about 3/16.
