JoseAMG
    Sun Oct 26, 2014 9:18 am
    San Luis Potisi,Mexico
Excuse my english but i'll try to explain as clear as i can.I've been assigned a project at this ranch where the electricity is realy low to the point where i have to krank the welding machine to its top amprage and i'm having problems keeping an arc lidd.Everytime i try to strike an arc the machine's energy goes way down and the rod sticks very easily.I'm using a small Lincon 140 amp arc welding machine with 6013 rod on 1/8inch tube.Some of my questions are,should i separate the rod more from the material and reduce my travel speed or is that not good?Or does it have to do with the rod angle as well?
Bill Beauregard
    Thu Jan 24, 2013 9:32 pm
    Green Mountains of Vermont
You are rolerskating in a gravel pit. If you can make it work you're a better man than I. You need an engine welder.
    Wed Oct 23, 2013 3:30 pm
    Palmer AK
I'm afraid your screwed mate....
You need to have a real welding machine to make real welds. :arrow:
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
JoseAMG,
Welcome to the forum!! It seems that we need to help you with the situation at hand. My first question would be what size electrode are you using? I would suggest to drop to a smaller size electrode and see if that will help you. If you are stuck with what you have you can try to long arc the rod to a point however there will be a point of demishing return. It seems to me if you have low power input you might have to make the best of what you have.
Jose,
I agree with Jonathan. A 1/8" 6013 will take 130-140 Amps to run well with good input power. If you can get and use a 3/32" 6013, you will be better able to adjust for the low voltage with a higher current setting than the rod would normally call for.
If you are stuck with the larger rod, yes, you can hold a longer arc to avoid sticking. Since you are welding 1/8 square tube, you should be able to do this without much trouble, as long as you don't have to get so long your arc wanders.
Don't apologize for your English; It's far better than my Spanish. Yo hablo solamente un poco.
    Eddy, TX
Otto Nobedder wrote: Yo hablo solamente un poco.
What did you just call me??? ;) :lol: :lol: :lol:
    Fri Nov 01, 2013 11:20 am
    Pittsburgh, PA
I call one dude in the kitchen senorita all the time, it irks him to no end because I won't teach him any swear words in English. So I get screamed at in Spanish by a 5ft tall Mexican dude while he's brandishing a knife at me. It's always a good time. #truckstoplife
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
The only other language I know is Pig Latin. Lol
weldin mike 27 wrote:The only other language I know is Pig Latin. Lol
How do you say, "E-Bay" in Pig Latin?
    Australia; Victoria
Ha. The struggles of an ancient language trying to deal with modern society.
Tassie Dave
    Wed Sep 03, 2014 2:04 am
    Tasmania
6013 2.5 rods.
I recently went online and bought some to re stock. The mob i buy from advertised these rods in a can. when the rods arrived they were in a card board box. no big deal there but the writing on the box was ALL Chinese. Thats where the fun started.
Any way i got one of my " rods out of the packet and did a run at 50 amps on my Esab and got slag inclusions in a lot of the run.
I put the amps up to 60 and repeated, same result. Up to 70 same result. Up to 80 same result. As a last ditch attempt i tried 90 amps which i know is way over the top and it still did the slag.
I tried a 3.25 rod burned perfect . Threw that rod in the bin. Any way this morning i went to the shed and tried it again, a super quick run on the 2.5 rod and it cam out half nice at 50 amps. ?
I am also in the process of making a dust trap for our cut off saw.
I have an
Esab LHQ 150
Pro Weld TC256 ACDC multi process Tig Cut MMA
WeldSmart Mig 200IGBT Mig Tig MMA and spool gun
    Australia; Victoria
The only rod with a slightly Asian name you should bother with are Kobe's. Made by Kobe steel from Japan. Very good quality. Some big name manufacturers operate in China but that's a different keetle of fish. Best home ones are satincraft 13s from Cigweld or a 12xp. (6012) can't go wrong.
    Sun Oct 27, 2013 10:57 pm
Tassie Dave wrote:6013 2.5 rods.
Could be the rods are not very good or you did not keep the flux lightly touching the plate.
I like running 3/32" (2.4mm) 6013 in the 75-100 amp range.
6013 2.4mm.GIF (40.97 KiB) Viewed 1941 times
Tassie Dave
    Tasmania
Thanks Mike.
I got stung on that one and from guys that i buy from regular. :evil:
I will give them a email asking for an explanation as to why.
I have some 7018's as well, they are a WIA brand. Nice rods but i prefer the Lincoln Easyarc because a lot of the work i do is Galvanised and i get less fumes.
I have an
Esab LHQ 150
Tassie Dave
    Tasmania
Thanks also Dave J i did try various lengths including just touching the slag onto the job and it made a slight difference but still had the slag. As i said that rod went to rod heaven and i tried another the following morning and got a damn good bead. All happy now. 75 to 100 amps. I can run 3.25's on that setting and get good penetration with my Esab.
I have an
Esab LHQ 150
    Australia; Victoria
Another awesome one is Ferrocraft 22s. (7014) the strength of a 7018 with out the need for a rod oven.
Tassie Dave
    Tasmania
Thanks Mike .
I may get some of those Ferrocraft rods 7014.
I have used varying sorts of rods here in Australia Lincoln rods for Gal work brilliant.
I also got some from Boat owners warehouse some china brand and they worked nicely. Slag curled up behind me and needed minimum cleaning.
I have an
Esab LHQ 150
    Australia; Victoria
No worries mate. Cheapest worst rods ive bought were Nuweld 3.2mm 6013s but that was back in the day when i wasnt the picture of awesomeness you see before you. hahahaha
    Palmer AK
weldin mike 27 wrote: (7014) the strength of a 7018 with out the need for a rod oven.
Really?
Then why even have 7018?
dsmabe
    Sat Sep 20, 2014 5:50 pm
Probably some over educated fool said so, or am I the fool? :|
    Australia; Victoria
7014s have no low hydrogen properties, therefore not for code/work, because the coating can not be certified with in the permissible difusable hydrogen levels of most codes. Pound for pound, its the same core wire.
dsmabe
Well, turns out I was the fool! But now this fool has slightly more knowledge, thanks Mick!
    Australia; Victoria
No worries cob. 7014 is a great allround rod (with in reason) because it has the strength of 70xx but needs no special rod treatment/ conditioning.
Bill Beauregard
I feel 6013 is like sex with a quadriplegic, it just lays there. I can't seem to do it in any other position!
