chadmh91
    Fri May 16, 2014 8:35 pm
I have to take a welding test tomorrow, 4 inch carbon steel pipe with stick, can anyone help me & explain how hot my machine should be & what size root opening I should use, I would really appreciate it...
    Wed Oct 23, 2013 3:30 pm
    Palmer AK
chadmh91 wrote:I have to take a welding test tomorrow, 4 inch carbon steel pipe, can anyone help me & explain how hot my machine should be & what size root opening I should use, I would really appreciate it...
Hey,
Let us know what kind of test???
Stick, Tig???
What "G"????
chadmh91
My bad it's an all stick pipe welding test
    Palmer AK
Up or down root???
What position???
5g, 6g????
kermdawg
    Tue May 25, 2010 8:16 pm
    All over, mostly southwest USA
chadmh91 wrote:I have to take a welding test tomorrow, 4 inch carbon steel pipe with stick, can anyone help me & explain how hot my machine should be & what size root opening I should use, I would really appreciate it...
Depends on what you are comfertable with. You have been practicing havn't you? What have you been practicing with? Every machine is differant. 80 amps on a miller is not 80 amps on a lincoln.
Really need the WPS of the test. Assuming 6010 root, 7018 fill/cap? 6g?
chadmh91
Uphill
6g
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
Well with the little information we have I have to assume you have never taken a 6G. More than likely it will be a 6010 down/hot pass and 7018 up fill and cap. There should be a WPS to go by. If not here is how I would do it but remember this is personal settings and may not suit you. For the 6010 85-95 amps down, add 10 amps to what ever you decide for root for the hot pass. For cover you can go anywhere from 95-120ish amps again depending on your style and what size rods you will be using. Again this is just me, I know others here do it differently and there is nothing wrong with that. For a gap I go 3/32"-1/8" and match the land. If you have no experience in a test like this, you better practice before you go....a lot.
Here is some videos to help
https://www.youtube.com/watch?v=pXDuDCL ... r_embedded
https://www.youtube.com/watch?v=q3yDSUe ... r_embedded
