jtornabene
- jtornabene
125A 7018 1/8”
109A 7018 1/8”
Should I be using a larger rod? Slower speed?
I am still struggling to watch the puddle while seeing where I am headed.
jtornabene
- jtornabene
Yes rod angle on 7018 is pretty forgiving you can push or pull it. It’s an all position rod. But arc length is much more critical to getting it to run right. Most common things I’ve found that create undercut with 7018 are, 1 not getting off the mill scale, 2 to fast of travel or not holding the sides long enough if your weaving, 3 long arc, 4 way too hot of amps for the thickness of metal or position of weld. It takes a little bit to get used to looking through the slag and trusting that the weld is doing what you think it’s doing. How thick was the steel? And was it beveled, and roughly what degree of bevel? Was it an open root , and was there land.
jtornabene
- jtornabene
The steel is 1/4” plate cut at 90 degrees and is an outside corner weld.Poland308 wrote:Yes rod angle on 7018 is pretty forgiving you can push or pull it. It’s an all position rod. But arc length is much more critical to getting it to run right. Most common things I’ve found that create undercut with 7018 are, 1 not getting off the mill scale, 2 to fast of travel or not holding the sides long enough if your weaving, 3 long arc, 4 way too hot of amps for the thickness of metal or position of weld. It takes a little bit to get used to looking through the slag and trusting that the weld is doing what you think it’s doing. How thick was the steel? And was it beveled, and roughly what degree of bevel? Was it an open root , and was there land.
Thanks for the responses.
jtornabene
- jtornabene
The shape of your ripples is the dead giveaway for me. Vee shaped ripples always mean you traveled too fast. Slow down, and give the puddle more time to fill in. If your weld is horizontal, pause a little longer on the top side of the weld and add more metal there to fight the pull of gravity.
Multimatic 255
jtornabene
- jtornabene
Would you expect to make two passes to fill it with 3/32?Poland308 wrote:If it’s only 1/4 inch metal I’d be running 3/32 at about 80 amps.
jtornabene
- jtornabene
Single pass with 3/32 7018. According to my amp gauge (which I think is wrong) I’m running 106 amps. I can’t keep from sticking striking the arc below that. I held longer on the top to try and fill in.
Yeah your amp gauge is off looks like about 40 amps off. Give it 5 or 10 more and that weld bead will smooth out. Side note. If your long arcing then you need more amps then someone who holds close. But long arc usually leaves lots of spatter. I’m not seeing that. Slow down just a bit more with the same settings .
jtornabene
- jtornabene
Poland308 wrote:Yeah your amp gauge is off looks like about 40 amps off. Give it 5 or 10 more and that weld bead will smooth out. Side note. If your long arcing then you need more amps then someone who holds close. But long arc usually leaves lots of spatter. I’m not seeing that. Slow down just a bit more with the same settings .
5 more amps and a little more patience. Holding the top twice as long as the bottom.
TraditionalToolworks
- TraditionalToolworks
jtornabene
- jtornabene
Thanks for the tips! I have struggled without any mentoring other than you tube.
