Building up a steel pin by brazing or O/A welding
Posted: Thu Oct 31, 2019 3:34 pm
I have a small issue with a trailer hitch and I am thinking about trying to solve it using my O/A torch. This is more for practice than need. I have an adjustable trailer hitch where the balls (two sizes on opposite ends of a square bar) attach into a channel with two steel pins. The pins are slightly undersized (I have not taken any measurements). They are undersized enough so that there is noticeable movement when I start or stop moving.
One thought was to build up surface of the pins by brazing. I realize this is soft and may not last, but I use the trailer very little, and it is less than 2000 pounds. The other thought is to build up the pins by O/A welding. I have done very little brazing and no welding. If I build it up too far I can chuck in into a lathe and turn or file it down.
I have 240 volt AC arc welder and 120 volt mig, but feel like playing with O/A. Also, assuming the Chinese pins are hardened steel (?), not sure about welding. I also through about partially filling in the holes on the channel and drilling or reaming them, but the channel is powder coated so I'd rather not fool with it.
