Been thinking about buying one of these, just curious how long the oxy tank would last.
Fuel gas heating, bending, welding, straightening, etc.
That’s what I keep on my truck. It last quite a while. Two acetylene tanks per oxy. I have a cutting head too. You can get tanks traded at most plumbing or HVAC supply houses for about 20$ per tank or less.
I have one tooLtBadd wrote:Been thinking about buying one of these, just curious how long the oxy tank would last.
The only down side is cutting steel
I have larger bottles for cutting and bigger Victor Torch
Just save for field work
Dave
Sent from my SAMSUNG-SM-J320A using Tapatalk
Are you doing more brazing then cutting? It always seemed to me (with cutting) that the oxygen always went low first.Poland308 wrote:That’s what I keep on my truck. It last quite a while. Two acetylene tanks per oxy. I have a cutting head too. You can get tanks traded at most plumbing or HVAC supply houses for about 20$ per tank or less.
Probably about 50 50 on the usage. I use a miniature rose bud for any brazing over 1/2inch. I have a small cutting head, but I’ve cut up to 1 inch thick plate with it. It runs about 10 on the acetylene and 40 on the oxy. Still about a 1-1/2 or 2 acetylene tanks to 1 oxy.
