Tooliom 135A Stick welder 110V/220V
Posted: Wed Nov 11, 2020 10:23 pm
Re: Tooliom 135A Stick welder 110V/220V
Posted: Wed Nov 11, 2020 11:12 pm
by DavidR8
I had a Liom machine and felt it was lacking something. I see that they’ve upped their game with the new Too Liom
Posted: Thu Nov 12, 2020 1:39 am
by tweake
Oscar wrote:
![Image](https://drive.google.com/uc?export=view&id=1oxIkZtNz8UERmy5Udms-LW5944qy_-am)
those specs look to good to be true.
do you have an amp meter to check it with?
Posted: Thu Nov 12, 2020 9:53 am
I have no doubt they are [too good to be true]
Yea I'll bust out the ammeter later on.
Posted: Thu Nov 12, 2020 10:45 am
by BugHunter
I'd be happy just to have the space all your welders take up!
Posted: Thu Nov 12, 2020 1:35 pm
![Screenshot_20201017-141011_Instagram.jpg](./download/file.php?id=17770&sid=cb2b5ea7a6945c7f607c54fe740f5860)
- Screenshot_20201017-141011_Instagram.jpg (58.54 KiB) Viewed 8826 times
Posted: Thu Nov 12, 2020 6:12 pm
It might do max amps at max duty..... once or twice. If it does it more than that then you got real lucky
Posted: Thu Nov 12, 2020 6:20 pm
LtBadd wrote:Screenshot_20201017-141011_Instagram.jpg
LMAO
Posted: Thu Nov 12, 2020 6:21 pm
Poland308 wrote:It might do max amps at max duty..... once or twice. If it does it more than that then you got real lucky
Lets find out this weekend, shall we?
Posted: Thu Nov 12, 2020 10:23 pm
Just another boring video
I6GIyBRFCSk
I hooked up the ammeter to it. On 120V input, it can put out an expected 95A, not 120+. On 240V input, it puts out a respectable 112A.
So on 120V you're limited to 1/8" 6011 or 3/32" 7018, and on 240V it can run just barely run 5/32" 6011, and just barely a 1/8" 7018.
Oh, and it can run cheap, off-brand "6010s", but it really can't run true 6010s. It will run "Ebay 6010s", but really if you ask me, those are just 6011s labeled as 6010s meant for the inadequate inverter crowd. Put some Lincoln 5P+, 6P+, Blue Demon/Best Welds 6010, Böhler Fox 6010s, and it chokes, as expected.
All in all, it's main caveat is the lack of hot-start. If you peck-and-lift, it just goes out or tends to stick. Dragging it for about ½ " like a long match-strike so as to keep the tip of the rod close helps it light-off much better. Once you accept and get past that, well, it does weld. Tripped the 20A breaker on 120V. I'm going to see if I can make it let the magic smoke out out this weekend.
Posted: Fri Nov 13, 2020 12:50 am
by tweake
some 3/32 rods. might be an okish cheap welder for someone to start on.
handy for doing small jobs and repairs. especially for hobbyist who won't use it a whole lot.
Posted: Fri Nov 13, 2020 1:37 am
tweake wrote:some 3/32 rods. might be an okish cheap welder for someone to start on.
Yeap, why not.
Ebay-6010s & 7018s on 1/4" steel. Not really worth the trouble (nor cost) of trying to run those EBay-6010s, which are like a cross between 6010s and 6011s. The arc is okay-ish, but not stable like a regular 6011 is.
![Image](https://drive.google.com/uc?export=view&id=1TCbAfRNooiJLfQDGKEoSVepWOJ1MpyVz)
Posted: Fri Nov 13, 2020 10:20 am
by BugHunter
I have a perfect use for that thing tonight. Today I'm making a set of hanger brackets for a gas furnace (420# unit) that's going to hang from a 15 x 6 x 1/2" steel ceiling beam. Something like that would be nice for welding on some stops to keep the brackets from sliding down the roof pitch. I anticipate drilling a hole and putting in a bolt to keep things in place. That could be taken right up a 12' stepladder and rip a quick bead on to save the time drilling.
It is a cute little bugger.
Posted: Fri Nov 13, 2020 10:56 am
BugHunter wrote:I have a perfect use for that thing tonight. Today I'm making a set of hanger brackets for a gas furnace (420# unit) that's going to hang from a 15 x 6 x 1/2" steel ceiling beam. Something like that would be nice for welding on some stops to keep the brackets from sliding down the roof pitch. I anticipate drilling a hole and putting in a bolt to keep things in place. That could be taken right up a 12' stepladder and rip a quick bead on to save the time drilling.
Want it? I'll sell it to you.
Posted: Fri Nov 13, 2020 11:19 am
by sbaker56
That thing is actually kind of cool, the 230v output is frankly disappointing to the point if almost seeming kind of pointless. But I'll run a 3/32 7018 at 90 amps all day long.
For 65$ you could almost buy one just to keep in your car or loan out. I dislike 3/32 6011 on anything around 1/4 for whatever reason, but 3/32 7018 and 1/8 6011 is a great combo for small jobs.
Posted: Fri Nov 13, 2020 11:24 am
sbaker56 wrote:That thing is actually kind of cool, the 230v output is frankly disappointing to the point if almost seeming kind of pointless. But I'll run a 3/32 7018 at 90 amps all day long.
Do you want it? I'll sell it to you so you can keep it in your car or loan out.
Not like I need it, lol. It's actually $90, but there is a $10 coupon on it, so you can get it for $80 shipped from Amazon.
Posted: Fri Nov 13, 2020 5:03 pm
by BugHunter
Oscar, Your sig needs updated.
Posted: Fri Nov 13, 2020 5:47 pm
BugHunter wrote:Oscar, Your sig needs updated.
Oh I'm not keeping it. I feel guilty for cheating! It was just a one-time thing, it meant nothing I swear!
Posted: Fri Nov 13, 2020 5:55 pm
It reminds me of an old ThermalArc 95 I used to have. Except it would run 6010 1/8.
Posted: Mon Dec 07, 2020 10:37 pm
