Chicago Electric 14inch chop saw
Posted: Fri Nov 08, 2019 9:27 pm
by WelderDan
I bought a -Chicago Electric- 14" chop saw from Harbor Freight. I bought a DeWalt blade for it. Lots of wobbling right out of the box. I took the blade off and tightened down the arbor assembly and it still wobbled a lot, so I know the blade wasn't the problem. It didn't cut straight either -- when the angle adjuster is set to 0 degrees it's way off. I have to give HF credit for a no-hassle return.
Re: Chicago Electric 14inch chop saw
Posted: Fri Nov 08, 2019 10:23 pm
Well at least you gave it a try.
Posted: Sat Nov 09, 2019 8:45 am
by BillE.Dee
Did you get your dollars back or did you replace it ? And if replaced, what is the outcome ?
Posted: Sat Nov 09, 2019 8:39 pm
by WelderDan
BillE.Dee wrote:Did you get your dollars back or did you replace it ? And if replaced, what is the outcome ?
I just got a refund. I read other reviews that the machine doesn't cut straight -- I can't stand that. Wobble in other reviews as well. I've got my eye on a Makita 14"...For an extra $80 ($180 total) I think it's worth it.
Posted: Sat Nov 09, 2019 8:48 pm
I have low expectations of any chop saw. I’ve never seen one that cuts true. Cold saw with a carbide blade yes or a band saw.
Posted: Sun Nov 10, 2019 7:30 am
by Coldman
+1
Don't waste your money on an abrasive chop saw. Brand doesn't matter, it's a failed concept.
Posted: Sun Nov 10, 2019 10:17 am
by homeboy
Coldman wrote:+1
+1
Posted: Sun Nov 10, 2019 10:20 am
by homeboy
homeboy wrote:Coldman wrote:+1
+1
Posted: Mon Nov 11, 2019 8:18 am
by BillE.Dee
I really don't have experienced those metal cutting circular saw blades. A friend of mine showed me his,,once. I was surprised there was not a lot of noise and no sparks. He only grabbed a piece of scrap metal to show me the workings of the thing. Don't know about fit up or anything. I was definitely ready to run and also surprised.
