Tig Amperage
Posted: Mon Jan 22, 2018 4:27 pm
by Cle808
Need a hand. I am preparing to test initially for my fillet weld tig test. We are welding on 3/8's carbon plate and are being told to use approx 140 amps. We are using 1/8 tungsten and 1/8 or 5/32 er70-6 According to calculators I can find this seems extremely low. Please advise me on what Amperage I should be at. Several samples we have cut appear to lack fusion deep in the corner of the weld.
Re: Tig Amperage
Posted: Wed Jul 25, 2018 8:06 pm
Little bit of a late reply. But I run 125-150 amps on carbon steel with 1/8 rod. Pipe or fillet. As long as you recognize your doing a multi pass weld.
Re: Tig Amperage
Posted: Wed Jul 25, 2018 8:18 pm
by MinnesotaDave
140 amps is way too low for me on a 3/8" plate t-joint fillet weld and 1/8" filler rod.
I'd be 180-220+ amps depending on position.
Re: Tig Amperage
Posted: Wed Jul 25, 2018 8:58 pm
I agree that there is room to turn up but it depends on if your trying to run it single pass or multi pass. How big the joint is and weather it’s susceptible to heat input or warping.
Re: Tig Amperage
Posted: Wed Jul 25, 2018 10:59 pm
by MinnesotaDave
Poland308 wrote:I agree that there is room to turn up but it depends on if your trying to run it single pass or multi pass. How big the joint is and weather it’s susceptible to heat input or warping.
But how will I attain my goal of tig welding at mig speed if I don't turn it up and move?
Re: Tig Amperage
Posted: Thu Jul 26, 2018 4:54 pm
That is an admirable goal. One I’m sure I’ll never reach.
Re: Tig Amperage
Posted: Sun Jul 29, 2018 4:20 pm
by Jarrod
MinnesotaDave wrote:Poland308 wrote:I agree that there is room to turn up but it depends on if your trying to run it single pass or multi pass. How big the joint is and weather it’s susceptible to heat input or warping.
Tig is slower thats is nature.
Re: Tig Amperage
Posted: Tue Jul 31, 2018 10:51 pm
by MinnesotaDave
Jarrod wrote:MinnesotaDave wrote:Poland308 wrote:I agree that there is room to turn up but it depends on if your trying to run it single pass or multi pass. How big the joint is and weather it’s susceptible to heat input or warping.
But it's not my nature
I like to move on out
