Greetings all,
Being new in my welding career I am not familiar with qualifying welding procedures.
My current job, 54" stainless steel pipe butt straps. My PM originally wanted to weld it with SMAW 308L electrodes which is not very time or procedure efficient. At least that's my assessment. I recommended using MIG with 316L SS wire. But to do that I would need to certify for SS and to do that I need to provide the testing site a WPS.
Can someone, anyone explain to me, in a nutshell, the process to qualify a procedure as per AWS D1.6?
Thank you.
- Easy10pins
Don't mean to sound like an ass. But I don't think there is a nut shell big enough. Believe Steve is working on setting up procedures for where he works. Slightly different scenario but same size effort needed. I know there's a lot of paperwork and that you need to be knowledgeable about the code book. You will essentially be making up your own weld test. Based on what fillers it will cover and what parameters. I.E. pipe work, flat work, metal thickness, weld position, bevel, no bevel, backer/ or not, purge / or not, and an endless amount of other options.
- Easy10pins
I copied this from another forum, I'd advise you to contact a local testing lab that can assist you in this process, good luck and post back on your experience.Easy10pins wrote:This helps. I will pass this along to my superintendent.LtBadd wrote:HERE is a link to a PDF file in my dropbox, it may be some help
- Easy10pins
LtBadd wrote:I copied this from another forum, I'd advise you to contact a local testing lab that can assist you in this process, good luck and post back on your experience.Easy10pins wrote:This helps. I will pass this along to my superintendent.LtBadd wrote:HERE is a link to a PDF file in my dropbox, it may be some help
Unfortunately, there's only 1 ATF in my area and they do not test for stainless. I'd have to drive 3 hours to the next ATF which is another part of the problem.
"Go as far as you can see and once you are there, go farther."
Qualifying a procedure should not require you to test at their facility. You can ship the coupons. That's what we're doing for ASME B31.1 and B31.3 stuff. Actually, I welded my ASME IX re-qualification piece at my shop and shipped it for testing. You only need proctors/witnesses that you followed the procedure you're testing/qualifying. If you claim 6G but rolled it out, the testing facility will know.Poland308 wrote:Don't mean to sound like an ass. But I don't think there is a nut shell big enough. Believe Steve is working on setting up procedures for where he works. Slightly different scenario but same size effort needed. I know there's a lot of paperwork and that you need to be knowledgeable about the code book. You will essentially be making up your own weld test. Based on what fillers it will cover and what parameters. I.E. pipe work, flat work, metal thickness, weld position, bevel, no bevel, backer/ or not, purge / or not, and an endless amount of other options.
Again, this is all ASME, and I can't promise AWS won't have different hoops to jump through.
Steve
- Easy10pins
And this is where my lack of knowledge is pretty evident. LOL.Otto Nobedder wrote:Qualifying a procedure should not require you to test at their facility. You can ship the coupons. That's what we're doing for ASME B31.1 and B31.3 stuff. Actually, I welded my ASME IX re-qualification piece at my shop and shipped it for testing. You only need proctors/witnesses that you followed the procedure you're testing/qualifying. If you claim 6G but rolled it out, the testing facility will know.Poland308 wrote:Don't mean to sound like an ass. But I don't think there is a nut shell big enough. Believe Steve is working on setting up procedures for where he works. Slightly different scenario but same size effort needed. I know there's a lot of paperwork and that you need to be knowledgeable about the code book. You will essentially be making up your own weld test. Based on what fillers it will cover and what parameters. I.E. pipe work, flat work, metal thickness, weld position, bevel, no bevel, backer/ or not, purge / or not, and an endless amount of other options.
Steve
Farmwelding
- Farmwelding
Yeah I started to read the d1.1 book and at 500 pages it is a long haul. And every tenth word I don't understand it seems like.Poland308 wrote:Code books can be intimidating.
Instagram: @farmwelding
Nick
Nick
