Anyone have any CWB fcaw tickets? Any tips on passing the flat position? Any info you can give is greatly appreciated
christhewelder75
- christhewelder75
Not many of us have access to Canada Welding Bureau specs but maybe someone will be along to help you with knowledge of that standard. I only know a little about CWB but from what I do know it has harder tests than we do in America. I would first advise you clean well between passes. Unless I am mistaken I believe the CWB does not allow mechanical cleaning in their tests so plan accordingly. What are the specifics of the test so we can advise better?
Be patient, Chris,
There are many members here from Canada, and some non-kanucks with experience. You may yet get a solid answer.
christhewelder75
- christhewelder75
On there it shows only one start/stop though some require 2 one on each root
