Nathannamaya
    Sun Dec 21, 2014 7:11 pm
Hey guys! Well should be pretty self explanatory by the title, but I was just wondering if you guys had any ideas for some beginners lathe/machining projects? Any ideas welcomed!
Check out Frank Ford's site at http://www.frets.com/HomeShopTech/hstpages.html. He's got a lot of good tutorials and some good projects. Also, just let your mind free-spool and start turning any off-the-wall piece you can dream up. One of the first pieces I turned when I got my lathe was a piece with a taper. It had no practical use at all, but it was certainly good practice. Lathes are cool. Just have fun. And always, even when it doesn't matter, try to hold to a preset tolerance. Just for discipline and to keep you honest.
Enjoy your lathe,
ldb
Miller Bobcat 225
Tweco Fabricator 211i
AHP AlphaTIG 200x
Lincoln SP-135+
Hypertherm Powermax 30 Air
ProStar O/A torch
    Sun Sep 22, 2013 10:14 am
    Minneapolis Mn 55407
get a copy of the Atlas/Craftsman
Lathe manual and machinist Tables---By the Clausing corperation
Pretty clear cut on all setup functions and how to. The later editions 70's and up best.
I got mine with lathe in 1977 and wore it out now have an enlarged copy in plastic pages /loose leaf 3 ring binder and it is always close at hand even 28 yrs later.
http://www.ebay.com/itm/1974-Sears-Craf ... 56742c65fd
The 12 x 42 Atlas is long gone but the book is still with my 14 x 40 Takisawa.
Like idbtx, tapers and threading is rewarding. It will come to pass"How did I get by without".
Now let the chips fly.
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
Diesel
    Wed Apr 15, 2015 6:03 pm
    Illinois
Ive been wanting to try doing a stainless steel mug or a small mini cannon that uses m80's or something. Im definitely going to try the mug soon.
    Wed Aug 06, 2014 12:48 am
    Melbourne, Australia
Nathannamaya wrote:Hey guys! Well should be pretty self explanatory by the title, but I was just wondering if you guys had any ideas for some beginners lathe/machining projects? Any ideas welcomed!
This is probably not 'beginners' level, but you can certainly learn a lot of all types of machinists tasks from this link, including lots of lathe work
