Advice on Plasma cutting Alum.
Posted: Thu Dec 18, 2014 3:12 pm
by Jason_alex
Hey guys I was wondering if any one had some advice on plasma cutting alum to get the best finish? 0
Thanks,
Jason
Re: Advice on Plasma cutting Alum.
Posted: Thu Dec 18, 2014 10:26 pm
Jason,
Where possible, I like to set it up to drag the tip directly on the surface. This makes the cleanest cut, and is fairly easy on Al because the oxide layer prevents direct shorting of the tip. Dry nitrogen is a bit of help if you have cheap access, but well-dried air will do fine, as well.
One advantage to direct-contact dragging is that you can use flatbar or angle (or a custom fence for curves and circles) as a fence to drag against without heating and flexing it as much as you would with the tip above the material.
Posted: Thu Dec 18, 2014 10:42 pm
by mcoe
Like Steve said if you can drag directly on the aluminum. Make sure that you have enough amps to cut the piece. If you are too cold it is horrible. Plasma does a pretty good job on aluminum. Here is a sample of some of the stuff I do with it.
Posted: Thu Jan 01, 2015 11:28 am
by Jason_alex
Worked great, I am using a little bit different set up I have a full CNC HD plasma table. Im so use to having a cnc I forget that plasma has the option to be hand held.... my bad.
