Ed from Ohiol
    Fri Feb 24, 2012 12:15 pm
To all Welders and Jody
Using a plasma cutter for portable use, what kind of compressed gasses can be used out of a tank in place of a compressor? O2, CO2, Argon Nitrogen? …
Which ones would you definitly not use? And why? How long do you think an 80 or 125cf tank would last,say at 100psi Thank you. Ed Oh.
nickn372
    Sat Jan 28, 2012 11:35 am
    Sugarcreek, Ohio
My experience with this is: Nitrogen work well and so does an air compressor if you have an effective method of drying the air. Some welding shops may have a small portable dessicant filter that will get the air dry enuff for a portable plaz. Looks kinda like a large oil filter. Happy cutting!
Be the monkey....
    Fri Feb 12, 2010 10:48 am
    YOUNGSTOWN, OHIO
Plasma Cutting - Recommended Gases
Compressed Air is the most commonly used gas for lower current plasma cutting and works well for most metals from gauge thickness to 1 inch. It leaves an oxidized cut surface. Compressed air can also be used for plasma gouging on carbon steel.
Nitrogen is often used for higher current plasma systems and for cutting materials up to 3 inches thick. It produces excellent quality cuts on most materials.
Oxygen is used when the highest quality mechanized cuts are desired on carbon steel up to 1 -1/4 inch thick. The cut face is smooth, and dross is easy to remove. Oxygen can also be used on stainless steel and aluminum, but it produces a rougher cut face.
Argon-Hydrogen Mixtures are generally used for cutting stainless steel and aluminum. They produce a clean, high quality cut face. Argon-Hydrogen is required for mechanized cutting of any material more than 3 inches thick. This mixture also provides an excellent gas for plasma gouging on all materials.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Ed from Ohiol
I appreciate your reply, thank you, Ed
    YOUNGSTOWN, OHIO
This is one of the better explanations of Plasma gas selections. As for the question of how long a bottle will last, that will depend on the material being cut. You could range from 40 psi to 90 psi depending on the material and thickness. Hope this helps
http://www.centricut.com/New_Lessons/lessons_9.html
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Ed from Ohiol
Thank you Jim, your info pointing to Centricut.Com is just what I was looking for. Ed
