Plasma Tip Getting Stuck to Work
Posted: Mon Sep 28, 2020 6:33 pm
by Chips O'Toole
I've been having problems with my plasma cutter sticking to work while I drag it across the steel. Is there something I don't know? I assumed it was made to be in contact with the metal.
It gets stuck, and then the cut opens up and gets ruined.
Re: Plasma Tip Getting Stuck to Work
Posted: Mon Sep 28, 2020 6:50 pm
Not all tips are drag tips. Some, you must have a stand-off distance that you yourself as the user must maintain.
Posted: Mon Sep 28, 2020 7:19 pm
by BillE.Dee
hey chips, what make cutter are you using? As Oscar stated, some of them don't like running against the material and some do. Some come with a attached stand off guide and some rely on the operator to maintain the standoff.
Posted: Mon Sep 28, 2020 8:33 pm
by Chips O'Toole
It's a Hypertherm. The tips are castellated.
Posted: Tue Sep 29, 2020 6:06 pm
There might be a worn bit inside the nozzle letting a short circuit form. Or there's a switch to change between drag and stand off tips.
Posted: Tue Sep 29, 2020 8:00 pm
by homeboy
Chips O'Toole wrote:I've been having problems with my plasma cutter sticking to work while I drag it across the steel. Is there something I don't know? I assumed it was made to be in contact with the metal.
I have a Hypertherm 30Air with a drag tip and it does the same to some extent. Not a real problem but interesting to know if this is normal or a technique issue.
Posted: Wed Sep 30, 2020 6:41 pm
by Chips O'Toole
The tip looks pretty bad. I'll replace it and see what happens.
